yung vios po ulet, amoy gas yung oil sa dipstik bakit po kaya?
don't be too paranoid bro. check mo muna underlying symptoms like may usok ba na white sa muffler? may leaks ba? otherwise, leave it all out and ignore it. baka di mo na makatulugan yan, mahirap na.
ahaha tenkyu sir... di bale papa change oil naman na yun ehehhe... due na rin.. natanung ko lang hehheehe
Gas engines normally have its Oil smells like GAS or sometimes burnt gas basically because it is burning gasoline in its combustion chamber, some of this combustion gasses escape past the piston rings (blowby gas). These blowby gas can leave soot inside the engine and as the oil main function is to clean the engine these soot will mix with the engine oil and therefore will smell like gas
kuya yapoy pasingit naman po
yun sakin kasi meron din white smoke amoy gas madalas po sya pag start ng engine sa umaga pero pag mainit na po makina nasa kalahati na nawawala po pero amoy gas pa din yun usok
wala nman pong oil sa dulo ng tambutso or itim na usok talagang white smoke lang po
pag ganun po ba may tama na piston ring ko or valve ? or tune up lng ? ano po ba gagawin ko kuya?
