Results 1 to 13 of 13
    Meron bang relay ang stock na busina ng Revo ? Kung magpapalit ako ng FIAMM magpapalit din ba ako ng relay. TY
    Most Japanese vehicles dont have a horn relay. MOst.
    Most likely, kailangan mo lagyan ng relay iyan coz matakaw sa kuryente ang fanfare horns.
    Ok paje thanks
    yung revo GL diesel 2000 ng dad ko eh walang relay yung stock na busina... pero itong revo GSX 2003 namin eh meron relay.. everytime na nagbubusina ako eh meron ako naririnig ng clicking sound sa loob ng dashboard... pag may time ako eh hanapin ko yung relay kung meron talaga then tanggalin kung bubusina pa din.. ..
    yun sa akin xwind na confirm ko lang na wala relay ng tangalin ko yun denso na bisina and try to locate yun relay pero la tumutunog na relay so na confirm ko na la relay....................pagkabit ko fiamm lagay ko lang yun relay and fiamm k na...............
    Aug 2003
    Ngek wala ba yung XTO? patay patay...kailangan malagyan sa aken ...pwede bang self installed yon?
    hehe or kailangan ng electrician...baka may pattern ka Sir Xwind :D kasi Fiamm din nilagay ko
    Jul 2003
    glenn, sobrang dali magwire ng relay.
    tingnan mo yung relay in a way na may 2 vertical posts and 3 horivontal posts. yung dalawang vertical, kabit mo dun sa existing horn wires mo. don't worry walang positive and negative yan. basta nakakabit.
    yung 3 horizontal, isa nun line from the battery tapos yung 2 to the horn. mamili ka na lang para madali gamitin mo yung pinakataas at yung pinaka baba. again doesn't matter which goes to the battery or which goes to the horn unless gagamitin mo din yung gitna. pero complicated pa yun. yung taas nalang at baba gamitin mo.
    o diba simple lang
    xwind has two line for hi and lo short 2+ and 2- (you can check only if u press the switch and using ohmeter) and terminate in 85 and 86 port(relay), then 30port to 10amp fuse to positive terminal of ur battery, and fiamm have 2 terminal 1 terminal goes to 87port of relay and the other 1 is body ground.
    relay:
    30 to positive batery with fuse 10amp(recta)
    85 to existing line positive
    86 to another existing line negative
    87 to fiamm hi
    87 to fiamm lo
    sana makatulong kaya mo yan no need for electrician...........diy
    Aug 2003
    MARAMING MARAMING SALAMAT PO
    :D :D Sir Bubbles and Sir Xwind :D :D
    no problem sir
    Jul 2003
    x-wind, memoryado mo yung numbers ng relay? ayus ka din ah
    sir just installed last week kaya tanda pa................
    May 2012
    good evening po mga master's may question po ako about stock horn ng revo 2003. may problem po kasi, nawawala po yung busina niya. parang nag-ddischarge! minsan meron pero mostly nawawala yung busina! ano po kaya problema nito? kung sa relay naman po, may pumipitik pa rin po sa relay. may contact pa po pero walang sound sa busina mismo. tama po ba na bka may nag-loose na wire sa relay?
    pa-help po! tnx
Stock Busina ng Revo
