My sister complained about the 'magaspang' performance of her FX (1995 Toyota 2C). She had an oil change 2 weeks ago (Delo Gold) where she replaced the oil filter and air filter as well. Then ayun na, hindi na daw suwabe yung tunog nung engine.
I drove the FX myself and I noticed the following:
- engine is noisier
- the 'pull' is the same
- a 'magaspang' acceleration while on 2nd and 3rd gear. Pag-shift ng 2nd (at 3rd), I can feel some grinding underneath (parang sa gears). Parang hesitant tumakbo (alam ko yung feeling na suwabe tumakbo eh, pero itong FX eh hesitant). Also, merong sound na parang 'engine' ugong......pasensiya na mahirap i-explain in writing.
I plan to bring this FX to the mechanic this weekend (na-default ako). I'm hoping that you guys can share your thoughts on what could be the problem (para naman me idea ako when I talk to the mechanic).
Looking forward to your responses. Thanks in advance.
Baka may hangin sa fuel intake. Check mo kung may leak sa fuel filter. Iyung konting leak ay di mo makikita unless you use a paper. Itusok mo ang edge ng paper sa mga possible pagmulan ng leak. You will see the paper na mababasa ng fuel kapag may leak.
A small fuel leak will cause air to come in the fuel system while engine is running. This will cause palya or engine vibration.
Anu ano ba dapat ipa-check kapag PMS? AFter oil change, oil filter change, and air filter change, ano pa dapat ang i-check? Meron bang equivalent and timing adjustment (gas engine) sa diesel engine? Meron bang tune up sa diesel?
