Results 11 to 12 of 12
August 2nd, 2017 09:30 AM #11
The "tagtag" on low profile tires is generally not much with suspensions nowadays, IMO. You feel more road irregularities (cracks, uneven patches) but the ride quality in terms of damping control is pretty much the same. I get more ride harshness from riding on hard tires (aired up between 35 to 40psi); that's where i can tell the difference between the good suspensions actually.
Try 205/45R17 tires. These are the usual sizes i think. You can also see if 205/50 will fit well (at least you have more sidewall with that size). On shocks, i would guess the more common available aftermarket shock is the KYB Sport or AGXs.
- Dec 2018
- 1
December 6th, 2018 08:02 AM #12Tanong lang po. Pag sa tire size na 205/50/16. Swak pa rin po ba yung 1.5 drop? Thanks po
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
