Results 1 to 2 of 2
- Jul 2010
- 166
October 12th, 2012 08:35 PM #1bakit po kaya mas maganda takbo ng koste ko pag konting bukas lang sa a/f mixture? (mga isang ikot lang po counter clockwise). pero ang problema naman po pangit po ang idle nya, mapalag. tapos pag bagong start namamatay matay, dapat po medyo tapakan ng konti ung accelerator ng matagal. pag binuksan ko naman po yung a/f mixture para mawala ang palag mahina naman po ang takbo, parang delay po ang arangkada lalo na pag naka on ang a/c, parang nalulunod pag biglang tapak sa gas. 2e po makina ko.
October 12th, 2012 09:18 PM #2
ipaoverhaul mo ang carburador mo sir. I think merun baradong injector. Then merun idler-up na dapat nagrerespond when you turn on the a/c...palitin na rin yun siguro. Pagbelow working temp (hindi pa properly warmed-up) the idler-up also increases the idling rpm of the engine. sa mga 70's na engine, walang idler-up, instead merun choke...so you engage the choke para mag-idler ng ayos ang oto until mareach ang operating temp.
the idler-up is usually activated by vacumm air...coming sometimes from the a/c or sometimes electronically controlled.
sa idling issue after ma-warm-up: check your car specs, merun yun recommended idling rpm (I hope merung tachometer ang oto mo), adjust fuel feed to reach that specs. air is almost never controlled....yung fuel lang talaga.
Hi sir! Question lang po baka may idea kayo. 1994 GLXi Lancer Itlog 4G92 - about 10yrs na rin na...
LANCER Itlog (93-96) Owners - Please Post Here!
