Results 1 to 6 of 6
    Aug 2006
    Here's a way to replace the bulb assembly on Toyota Innova, Fortuner, and Hilux using ordinary peanut bulb which is P10/piece only.
    You also have the option to buy this bulb assembly only from Toyota Parts and service at P289.12/piece + Tax (Toyota Part number - 84999-10530, bulb assembly)
    Center panel removed, access to aircon control assembly and 2-DIN stereo.
    To be continued......
    Aug 2006
    To remove the aircon control assembly.
    Bulb can be access from the back of the aircon control assembly by rotating it counter-clockwise.
    Steps to replace bulb with inexpensive 10 pesos peanut bulb:
    1. remove the busted bulb from its holder/socket, untied its wires and pull the busted bulb.
    2. remove the green condom/rubber from the busted bulb and keep it safe for while.
    3. Smallest peanut bulb can be bought at any small or large auto supply at P10 /piece. Stick out the wires of the peanut bulb and straighten it parallel to its body.
    4. Insert the peanut bulb to the holder/socket and making sure the lead wires passes through the holes. Use small wires or staple wires to wrap along the canals of contact grooves and connect this wire to the peanut bulb wires.
    5. Put the green condom/rubber to the converted bulb.
    6. Put back the bulb assembly on the aircon control panel, and test the bulb by turning on the park lights.
    Hope this helps...
    * sir Mile2,
    Your post is definitely helps , hope to see some more informative post like this. thanks
    Oct 2009
    sir pwede pa post ulit ng pictures? thanks
    Feb 2013
    Up baka pwede ma repost.
    Oct 2009
    Picture ba ng pagkalas ba ng ac control assembly as well as the hu over ang hanap ninyo?
    If yes, merun lang isang screw (philipps) sa center knob yun...so pull-out the three knobs ng ac (kung dial type ang ac ninyo). Yung nasa gitna, merun siyang screw. Remove that with a philipps driver (+). Then hold the lower portion of the ac cover and pull outward with a SLIGHT jerk. Then ilipat mo ang hawak duon sa bandang itaas (yung dalawang "butas" na holder ng samut-sari) and pull it outwards ulit with a slight jerk. Dapat mag snap-out na yun.
    Disconnect the hazard switch wire (merun clip lock yun). That's it....you'll gain access na sa bulb as well as the HU. Puede mo ng palitan ang HU
Innova/Fortuner/Hilux center console backlight expensive bulb replacement tricks
