Results 1 to 19 of 19
    Jun 2008
    Good day! Mga Sir's. Ask lang po kung may idea kayo regarding sa radiator and coolant. Lately po kasi nauubusan ng coolant yung radiator and reservoir ng avanza namin 2008 model. Wala naman po sya leak sa radiator. Wala naman din problema sa gasket. Hindi po kaya sa water pump? Idea lang po. Maraming salamat! TIA! God bless!
    Jun 2008
    Pahabol din po baka may ma-rrecommend kayo repair shop engine and aircon san juan area. Salamat po ulit!
    Jan 2008
    check nyo din po sa hoses baka lose na yung clamp.. possible na water pump din po. makikita nyo po na merong basa sa sahig kapag nag-overnight park kayo. ganyan po kasi nangyari sa innova namin
    What's the mileage of your Avanza? Have you checked your radiator cap?
    Did you overheat or your engine temp is still okay as long as you have coolant? How fast does the coolant disappear? Any leaks in your garage when you park overnight? Did you check your engine for any dried coolant traces (use a flashlight and check areas near the hoses).
    In San Juan, try Speedyfix along P. Guevarra/Seaview Sts.
    If you change your radiator cap, go for OEM Toyota or Denso. Mura lang ang Denso (mga P250 at Toyorama, Banawe).
    Hello,
    check your aux fan motor. minsan yan hindi uma andar kaya kumukulo water then lumalabas via the reservoir. that happened to my 2006 avanza. I changed my cap, hoses, water pump only to find out when the aircon engages the motor fan should engage also. Hindi pwede na mag engage ang aircon na hindi mag engage ang aux fan.
    Aug 2005
    Quote Originally Posted by gensi311 View Post
    Hello,
    Walang aux fan. rad fan lang ang typical sa toyota
    sorry,
    thats what i mean. the aux fan and radiator fan are incorporated into 1 fan lang.
    I changed mine. just the motor of the fan. everything is fine now.
    Jun 2013
    Quote Originally Posted by ryFAXX View Post
    Hi,
    Sorry late luma na pala yun thread. Were you able to solve the issue? Nangyari narin yan sa akin before 07 model. Radiator cap lang yun issue. Replaced and issue resolved.
    Sep 2016
    Ito rin exactly problem ng sasakyan ko ngayon 2008 avanza. Hindi na namen magamit ang aircon for few months now. I remember sinabi ng mekaniko aux fan nga raw. ngayon naman paubos na yung coolant and gusto ko sana ako magdrain ng coolant at magflush kesa gumastos sa mekaniko. wala sa google or youtube kung paano idrain ang coolant ng toyota avanza specifically.
    Patulong naman kung saang parte ng avanza yung drainage ng coolant at pakiexplain ano kinalaman ng coolant sa aux fan/rad fan at hindi magamit ang aircon. magkano na rin ang pagpapaayos.
    Quote Originally Posted by ani View Post
    Check Mo kung Meron drain plug sa baba ng radiator. Kung Wala Alisin mo yun lower house na galing engine
    If the coolant is going down it is probably caused by a leak, check the coolant hoses for residue. Change all the hoses and clamps if you can find the replacements. Worst case scenario is a gasket leak.
    If you want to drain the coolant, most radiators have a plastic drain plug. You can flush the radiator and replace with 50/50 coolant mix.
    wala akong avanza.
    but ayon kay google, merong radiator drain yan. google nyo po. mukhang simple lang naman, base sa pictures. (hirap basahin yung indonesian {malaysian?} lyrics.)
    errr... nawala na ba ang owner's manual, po? nandun yata ang instructions.
    walang kuneksiyon ang radiator coolant sa aircon.
    but, some cars' aircons are designed to quit when: 1. low on freon; 2. overheating engine, for whatever reason.
    good luck, po.
    paayos? depende kung ano ang sira, po. maraming puedeng mangyari, e...
    kung gagananciahin, low on freon lang.
    kung mamalasin, may leak sa kaloob-looban ng sasakyan na hindi mahanap-hanap.. palitan lahat ng tubing! or, may leak ang compressor mismo! heh heh.
    Jun 2005
    Kung di ka sanay mangalikot sa kotse mo, pagawa mo na lang tapos panuorin mo paano.
    Madami nasisira sa pagtitipid. Personally, madami na ako nasira pero considered "tuition" ko nlng sya sa exprience. Hehe
    Apr 2011
    Good day mga sirs/mam! Ask ko lng regarding s coolant ng avanza ntn. Malapit na kasi mag low yng coolant ng vanzie ko. Plan ko xa lagyan. Pwede po b yng nbli ko n Long Life Coolant Pro 99? Or anyone here n nka try n po nun? Thank po sa sasagot. God Bless us all!
    Sent from my SM-A720F using Tsikot Forums mobile app
    Feb 2014
    Quote Originally Posted by kuchan17 View Post
    older toyotas used the red coolant. newer ones use pink
    parang honda type1 and type2 yan
    they're not interchangeable
    Apr 2011
    Quote Originally Posted by Vodka View Post
    Yes sir. Pink nga yng nbli ko. Pwede kya yng brand n Long Life Coolant n nbli ko sir? Thank you s pagsagot sir.
    Feb 2014
    original coolant mo is toyota pink? this is the super long life coolant, lasts many many years. check your manual
    top up w/ toyota pink coolant only. don't mix
    when it's time to replace the coolant, use toyota pink coolant only
    don't experiment w/ coolant, not worth the risk
    there's this "Pro 99" pink coolant selling at the mall. does anyone know if this is toyota-spec?
Avanza coolant problem
