Results 1 to 10 of 10
    Dec 2009
    i used Havoline with deposit shield 20W-50 and it runs better it reach around 135km/h..& recently i added Valvoline VR1 racing oil sae20W-50.. is sae20w-50 best for a 2E 1300cc carbureted engine? help me please.
    Jun 2008
    VR1 same one i use on my track toy cant go wrong with that, 20w-50 your fine with also i use 20w-50 on summer also, 10w-30 on winter time your good keep it up.
    Jun 2009
    20w-50 is good for your engine since a bit old na ang engine. pero try mo rin ang 10w-40 kung walang leak ang engine mo mas magaan kasi ang feel nito.
    Quote Originally Posted by achilles_0827 View Post
    I also use 20w 50 on my 2E motor and shifted to 15w 40 less weigt and improved my fuel consunmption.
    Dec 2009
    thanks sa reply nyo. i appreciate it. pero can i ask what's the difference of 10W-30, 15W-40, and 20W-50?
    Jun 2008
    its just viscosity grade, the higher the number thicker the oil, on hot weather like philippines you may want a thicker viscosity like 10w-40 or 20w-50. Specially your 2E is old and i bet compression is a little off ok way off the original ratio.
    Mar 2007
    Here's an article link for your question... it's everything you need to know about oils (well... almost :-) ).
    http://newoil.blogspot.com/2009/04/e...now-about.html
    I hope this helps.
    Dec 2009
    Thanks. So do you think i'll stay using the 20W-50 for my 2E?
    Jun 2008
    You'll be fine... I use 20w-50 VR1 racing on my track car for 4yrs now, one thing i like about it is after all day of 9,200rpm redline to redline VR1 will not thin out on you.
    Dec 2009
    Thanks for that. i'm just new to VR1. i hope it will give me another years to come.
What oil is recommended for TOYOTA COROLLA 2E 1300cc?
