Page 1088 of 1549 FirstFirst ... 98810381078108410851086108710881089109010911092109811381188 ... LastLast
Results 10,871 to 10,880 of 15485
    Jan 2009
    #10871
    mga sir mga how much ba yung front shocks? nung nag pa change oil ako sa shell may leak na daw. nasa 50k na din tinakbo.
    #10872
    Quote Originally Posted by frequenzy View Post
    there are two usual choices. kyb. white or black. 1.5 or 2.5 thousand bucks, more or less.
    i recommend the black.
    i tried the white. matigas.. matagal bago lumambot.
    my experience.
    my experience.
    #10873
    Quote Originally Posted by dbcfutbol View Post
    Hi Guys
    I need help
    My oilfilter in my innova is stuck
    Ang hirap tanggalin
    I already punched a hole kaso di parin kaya. Now im looking for this 3 legged oil filter wrench.
    Anyone knows where i can buy it?
    Thanks
    my old oil change mechanic used to punch a small pitchfork thru the head above, then twist it away. the replacement is just hand-tightened.
    i suppose you can do it easier from below..
    #10874
    Car Door/Alarm problem
    After central locking and enabling the alarm, the door unlocks intermitently in varying lengths of time. Anyone who had the same problem? Solution?
    #10875
    Quote Originally Posted by nujsimon View Post
    is it possible, your (other) remote is being buffeted around in someone's bag nearby or in someone's tight-fitting pants pocket? the button might be prominent enough, as to be accidentally pushed by adjacent objects..
    have them remotes in front of you and see if the problem persists.
    Oct 2014
    #10876
    Nagpa sound setup ako kahapon, matagal naka bukas yung door kasi ginagawa nga. nung nakauwi nako napansin kong nawala sa alignment yung door. parang bumaba siya ng konti kaya medyo mahirap isara.. madali lang ba e-adjust ito? at saan ito aadjust?
    Aug 2015
    #10877
    Ganun ba...sige.hanap hanap na lng ako banawe.hehe
    Aug 2005
    #10878
    Bought sa cruiser sucat orig is 2,850...mura na para sa original...900-950 ata yung rear... I already replaced all shocks...
    Oct 2013
    #10879
    Quote Originally Posted by Salamander13 View Post
    Kung sa unahan yan, tangal ka fender.
    Oct 2014
    #10880
    Buti nalang rear driver side door.
    Quote Originally Posted by vvti2.0 View Post
Toyota Innova Owners & Discussions [continued 3]
