Page 779 of 1549 FirstFirst ... 679729769775776777778779780781782783789829879 ... LastLast
Results 7,781 to 7,790 of 15485
    Aug 2006
    #7781
    Quote Originally Posted by kristine123 View Post
    How about sa loob Sir Mile? hindi ba delikado pag ma sprayhan sa loob ng muffler?
    Sa labas lang ang pinturahan? Thanks
    Yes yung loob puede sprayed with HIGH TEMP paint, pahiran mo muna ng rust converted para matanggal yung mga kalawang, let dry before using the car, Yung paint inside the tail pipe end ko siguro mga 5 years na, hindi pa naman natutuklap.
    Aug 2006
    #7782
    Quote Originally Posted by jovill View Post
    Mga sirs, meron ako prob sa 2006 innova j ko. Kapag nababad sa araw yung oto at binuksan mo yung aircon, di nag on ang 2nd and 3rd row aircon. Pag medyo tumagal na tumatakbo bigla na lng mag on o kapag inoff mo makina at start ulit, back to normal na naman yung rear aircon. Ano kaya prob dito? Pag di naman nababad sa araw yung oto, walang prob sa rear blower normal naman ang operation. Nornal pa rin naman ang lamig ng aircon at buga ng fan. Baka meron na naka experience sa inyo ng ganitong sitwasyon. Thanks!
    Sent from my GT-I9300 using Tsikot Car Forums mobile app
    Kung di pa nakaranas ng aircon cleaning ang car mo, its about time na pa cleaning mo na, once kasi ma dismantled yung mga part ng aircon it would be easy for the technician to check the failure point. My guess would be the wiring connectors needs contact cleaning or relay problem, but then again it would be best to bring it to aircon shop for diagnosis.
    #7783
    Sir what i meant is that the rear blower does not work if turned on. It will only after a while. So no air is comng out of the rear vents even on max setting.
    ah ok...
    what i can suggest is you check the fuses, electrical connections and relays up front and under the dash..other than that, you may have to bring the car to the aircon guys, who will probably tear into the ceiling switch and rear blower mechanism compartment...
    #7784
    Quote Originally Posted by Mile2 View Post
    thanks Sir Mile2, upon changing stock spark Plug to Iridium Spark Plug, Need pa ba reset ECU?
    Aug 2006
    #7785
    There's no need, Plug and play naman kahit anong spark plugs. If you look at the riveted aluminum notes at the engine bay, "you'll read no adjustment needed" when changing spark plugs.
    Aug 2013
    #7786
    hindi siguro. ganyan din ako kung gumamit... wala namang discharge problems..
    consider the possibility of dying battery. gano na ba katagal yang baterya sayo?
    Hay naku! Diskarga na naman battery ko after 10 days sa parking! The battery is 3 months old and the unit is just a little below 3 months. Kagagaling ko lang sa casa prior to parking for that 10 day stretch. Iniwan ko pa overnight yung unit para daw mas thorough ang testing. Everything is OK daw. Ngayon sinasabi naman ng SA ko na baka daw kasi iniwan kong armed yung alarm. E para saan nga ba yung alarm! Secure yung parking sa loob ng condo and may katabi na auxillary unit na may nakatira. Walang reports na nag-trigger yung alarm pati sa log ng mga guards. Sorry guys, I had to blow off some steam and ask kung kaya ba talagang gawin ng alarm na mag-drain ng batteries in 10 days kahit hindi na-tri-trigger?
    Dec 2007
    #7787
    Quote Originally Posted by Pao11 View Post
    If that is the only aftermarket accessory (electrical) na nakainstall then it's highly likely the culprit. Ipadisconnect mo muna yung electrical connection then imonitor mo for a few weeks.
    Jul 2010
    #7788
    Magandang umaga mga ka-innova.. hingi po ako ng advice. kahapon 16 Nov 2013, lumabas ng bahay ang mga anak ko for church services at 3pm. approx 50 meters biglang namatay ang car. tinulak ng mga anak ko pabalik ang car s garage para much safer. (1) Cover po ba ito ng Warranty? (2) Paano po kaya pwedeng mapadala sa Toyota Service Center, Alabang (3) Pwede bang ipagawa sa iba?
    Innova J Diesel 2012 ang car. Binan kami nakatira at ang Toyota Alabang ang pinakamalapit sa amin. Malakas ang busina at meron ilaw. Unfortunately, wala po ako sa Pinas kaya ang anak ko ang gumagamit at wala rin idea kung ano ang dapat gawin. Maraming salamat po sa lahat ng mag-aadvice and magsuggest ng pinakamainam na dapat gawin.
    Dec 2007
    #7789
    Quote Originally Posted by shekyna View Post
    Ipa tow nyo na lang papunta ng casa. Usually the compre insurance includes free towing. Try and contact the towing company or call toyota alabang to arrange a tow truck pick-up. I'm assuming they attempting to start the vehicle with no luck. Nagreredondo ba ang makina?
    Oct 2011
    #7790
    Kung hindi na ma start ang sasakyan, sa insurance sir meron silang free road side assistance. patulong na lang kayo doon para dalhin sasakyan niyo sa toyota alabang.
Toyota Innova Owners & Discussions [continued 3]
