Results 5,921 to 5,930 of 15485
- Jan 2013
- 686
April 17th, 2013 08:24 AM #5921napadaan ako sa blade kahapon sa eastwood.. sakto may nakita akong muffler cutter na medyo malaki kesa sa OEM.. binili ko na at ako na lang nagkabit.. PhP495 ang damage.. maganda rin kinalabasan nung makabit ko..
kaso pag umaarangkada may tumutunong na parang maluwag yung pagkaka kabit ko eh mahigpit na naman yung mga turnilyo.. paano kaya diskarte dun?
maraming salamat..
April 17th, 2013 09:03 AM #5922
Thank you Sir Mile,
Between the two (Denso Copper vs Denso Iridium) when considering the following:
Price, life expectancy, performance and fuel efficiency. whitch item would you advice? Does the price difference(about more or less 800php/piece) justify the advantages of Denso Iridium?
TIA
April 17th, 2013 09:05 AM #5923
April 17th, 2013 09:08 AM #5924
April 17th, 2013 09:22 AM #5925
Already tried both copper and iridium., Iridium does not translate to high fuel efficiency but on performance, if you use your car on mostly on city driving it is better to use Copper and have it replaced every 10K-20K Kms., if you use your car mostly on highways use iridium and replaced them every 40K-60K Kms.
But since, my ride was on LPG most of the time, I have also tried one step colder plugs which is Denso IKH22. in terms of performance this is so far my best choice.
April 17th, 2013 09:38 AM #5926
April 17th, 2013 10:15 AM #5928
April 17th, 2013 02:23 PM #5929
I just want to ask, may ka-innova ba tayo na nagpa-install ng 2din with GPS sa tsikot sa Taguig, kay Jedi? I tried to update the maps but unfortunately, di ko na siya magamit ngayon. I tried to go back to tsikot shop pero sarado na. Can somebody help me on this? I tried to go to other manufacturer pero sabi nila di nila ma-update yung map kasi daw may serial number yun, sa dealer lang pwede. Di ko na rin malocate yung dealer. Help!!!
April 17th, 2013 07:56 PM #5930
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
