Results 1 to 10 of 3575
- May 2013
- 22
August 14th, 2013 10:24 AM #1
August 14th, 2013 11:09 AM #2
I've been using Shell Fuelsave or any 93 octane equivalent sa ibang gas stations and getting 9-10km/l in my altis AT.
Simula nung nagchange ng RON rating ang shell fuelsave from 93 to 91, napansin ko na parang 7-8km/l na lang fuel consumption ko.
Nagpakarga ako vpower kahapon. Observe ko muna..
- Nov 2011
- 68
August 16th, 2013 09:30 PM #3Hi guys,
I'm going to Baguio next week. Any recommended preparations for my Altis po (2012 1.6G MT)?
- Feb 2009
- 32
August 19th, 2013 06:36 PM #4
- Nov 2011
- 68
August 19th, 2013 09:28 PM #6Hello guys, thanks for the very helpful info! Noted po lahat. Also, stay safe dami baha today
August 19th, 2013 07:06 PM #7
Agree w Renzo. Not much to check if your ride is serviced regularly. Check your air pressure and your spare tire as well. Better to run a little more (33-35psi cold). This helps protect the tyre a little more against errant potholes too.
If youre loaded up, ingat din sa sayad ng nguso at tailpipe.
August 19th, 2013 07:14 PM #8
I just found out na casa inflated my tires from 30 to 33. Kaya pala it runs better. Pero nakaindicate sa car 30. Can I make it 33 instead? Is it bad for the tires?
Sent from my GT-N7100 using Tapatalk 4 Beta
"Man is least himself when he talks in his own person. Give him a mask, and he will tell you the truth."
August 20th, 2013 01:16 PM #10
That's the only time i'd get Starbucks. hehehe... cheapskate.
The problem i had with the HSBC/Caltex promo was the lack of coordination and clear guidelines disseminated to Caltex dealers (and to the gas boys or cashier). Several times i was refused at some stations because they did not recognize the charge slip (but the same was accepted at another station, and cleared with HSBC when i called). You also get the second rate feeling treatment when you try to redeem; i guess it doesn't help that i usually used the promo to load up our "old" Sentra. Stressful given there were times i went out of my way just to pass by the Caltex station. There's another reason but i can't recall anymore.
Yikes that(tesla) is even worse although upon some additional reading i'm not even sure our Seagull...
BYD Seagull
