Results 14,951 to 14,960 of 14970
July 19th, 2010 12:27 AM #14952
- Sep 2008
- 77
July 19th, 2010 12:32 AM #14953
July 19th, 2010 10:07 AM #14954
July 19th, 2010 10:40 AM #14955
*egaieskie03.... thanks, nakita ko na yung module sa lower left side dashboard ng driver seat... nakita ko na rin yung mga respective assignment ng mga fuse sa user's manual. Ang problema, di ko pa tinitignankung busted kasi hindi ko alam kung paano malalaman
. newbie lang po
July 19th, 2010 10:45 AM #14956
July 19th, 2010 12:30 PM #14957
Mukang nag fail alternator, lumusong ka ba sa baha? baka inabot alternator. nangyari sakin yan pero di sa vanzy malalim baha yun inabot alternator nasira AVR... yung honda ko naman dati nangyari din di naman ako lumusong sa baha sobra lakas lang buhos ng ulan then naka bright headlight todo wiper naka hazard tas naka aircon then unti unti humina lahat pero ginawa ko nagbawas ako load patay aircon hininaan ko wiper yun nag normalize. Pinapasok kasi ng tubig mga wires, terminals, alternator, kaya nagiging grounded or partly grounded nagkakaroon tuloy ng dummy load. Kaya nga ako yoko na lumusong sa baha dami nasisira.
share ko lang experiences ko and little knowledge sana makatulong sa lahat
July 19th, 2010 01:34 PM #14958
Gumana naman lahat except sa lima
So not the alternator,
Could be the relay, recheck ko mamaya ang wiring diagram ng avanza natin...
Gumagana paba ang Horn?
[edit]
Can you check both the IG Relay and IG Fuse...
Check 1st the IG Fuse(40A) located * Engine Bay.
The if fuse is OK, check the IG Relay located * kick Panel.
.Last edited by xda2jojo; July 19th, 2010 at 02:33 PM.
July 19th, 2010 02:46 PM #14959
correction:
Can you check both the IG Relay and IG1 Fuse...
Check 1st the IG1 Fuse(40A) located * Engine Bay.
July 19th, 2010 03:54 PM #14960
nalubog pala eto sa ondoy,
check mo na din baka nagkaroon ng loose contacts ang mga dulo ng wirings inside fuse box.
Yan ang pinaka possible na probs kung ok ang mga fuses and relay.Last edited by xda2jojo; July 19th, 2010 at 03:58 PM.
Hi sir! Question lang po baka may idea kayo. 1994 GLXi Lancer Itlog 4G92 - about 10yrs na rin na...
LANCER Itlog (93-96) Owners - Please Post Here!
