Results 11,621 to 11,630 of 14970
December 13th, 2008 07:41 PM #11621
December 14th, 2008 01:09 PM #11622
Pag marumi, dito lang sa bahay ang washing with car shampoo. Pag maalikabok lang, CCD lang ang gamit.
Ginagawa kasi ang SLEX at sa mga areas na tinatapalan kaya siguro nakakakuha ako ng asphalt.
Nag nag road trip na malayo with the kids, autonatic na magpa carwash ako sa labas. Habol ko kasi ay ang vaccum.
Mga every month or every 2 month ako mag wax. Mothers ang gamit ko. Step 3 lang nga. Pero after ng wax, iba ang kintab at parang "wet look" pa. :D
Buti na lang hindi umulan kahapon. Pero ang ZZ namin ay basa. Naulanan sa parking sa mall. Nasa fort area ako kahapon.
December 14th, 2008 03:33 PM #11623
December 14th, 2008 08:31 PM #11624
December 15th, 2008 11:47 AM #11625
December 15th, 2008 12:20 PM #11626
Galing sa http://www.autogeek.net/motcalgolcla.html (Mothers™ Clay Bar Paint Saving System) :
2.82 oz. Mothers™ Clay Bar
This synthetic clay bar is a moldable compound that grabs tiny contaminants as you drag it across the paint surface. It is nonabrasive, contains no chemicals, and will not alter the paint in any way. Even though it sounds tough, and it is, Mothers™ Clay Bar is completely paint-friendly. You can use it with confidence no matter what your level of detailing experience.Mothers™ Clay Bar Paint Saving System is quite easy to use. The yellow clay has a soft yet firm texture that will not crumble as you use and re-form it. The first step to a glass-like finish is to thoroughly wash and dry your car. Once you are satisfied with the clean, rub your hand across the paint’s surface. Does it feel pretty smooth? Sure it does... Now start working with the clay! Work small sections at a time...spraying first with Showtime and placing Mothers™ Clay Bar on the dampened area, gently moving the bar across the surface in a back and forth and up and down motion. Don’t use a circular or swirling method when applying the clay. You may notice a gritty resistance and sound. This is normal and will dissipate as the surface is cleaned. Once the clay moves without any resistance the surface is clean. Now feel the paint surface, you’ll be awed by how much smoother it has become! Move on to the next section, always remembering to slightly overlap the previously clayed area. You will begin to see a reddish brown deposit residue forming on the clay bar. This is the grime being trapped within the clay and away from the paint surface. As the clay bar becomes soiled, fold it over itself and reform the sections to reveal unsoiled clay.
Don’t forget to always keep the surface wet with Showtime while using the clay bar. Follow the clay treatments with polish and wax. Showtime can be used between washes as an instant detailer.
December 15th, 2008 12:23 PM #11627
^^^ di kaya ng powers ko iyan. Siguro, magpa detail na lang ako para hindi ako pagod. hehehehehe.
Ilan oras ang ganyang operation pag DIY?
December 15th, 2008 01:43 PM #11628
December 15th, 2008 04:37 PM #11629
sa BBs pag nagpapa wax / paint protect.. ginagamitan nila nang clay after nang hugas.. tapos ni spray-an din nang kerosene yata.. sa lower portion.. pan tanggal nang asphalt.. then banlaw agad..
Baka may big discount sa Corolla Cross V?
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
