corolla GLI 1995 model
ano kaya yung sound na yun ok naman gear oil. any treatement o conditioner na pwedeng ilagay sa transmission
For manual transaxle:
Gear lubricant 5 (85W140). Check your front wheel bearings and CV joints, check your brakes
tuwing kelan lumalabas ang ingay?
accel, cruising o deceleration? or at idle?
or
sa anong gear position? 1st, 2nd, etc?
or
clutch pressed or not?
or
kapag kumakabig sa kanan o kaliwa? or straight ahead?
or
or
or
If its confirmed that its within the transmission, pull it down and have the bearings checked. Happened to my Revo before. While I was on my 4th to 5th gear, every time I press the gas, I hear a somewhat whining sound. Kung minsan dinig ko parang may motor na sumosunod sa akin. Nung binuksan, nakita yung dalawang bearings connected dun sa final gear na worn-out na pala. Replaced the bearings as well as the gear oil. Now its super quiet already
Check your wheel bearings and front wheel hubs for this noise while under load( weight of the car on the tires)
If you have antilock brakes, this is confirmed by a noisy signal of the wheel speed sensor on an oscilloscope
