Results 1 to 6 of 6
January 5th, 2007 01:11 AM #1
Iyung Bro-in-law ko bumili last week ng Lucida sa subic. iyung may mga lucida..... ano ba ang advantages at disadvantages ng Lucida.....
post ninyo naman. para tulong narin sa bayaw ko.
- Dec 2004
- 48
January 27th, 2007 09:01 PM #2kung subic yan malamang converted yan from right hand drive ...... so first thing you have to be aware of and double check if the conversion was done very well.
turbo
- Nov 2002
- 503
January 27th, 2007 09:27 PM #32 LT engine, overheat ang sakit. Pareho ng Surf ang makina, kung di pa pinapalitan ang head, cguradong cracked na.
Di kya ng 2LT ang prolonged 100KPH run. Pag nagboost ang turbo, yung tubig mo cguradong magbabawas, cguradong overhaet.
Rear passenger door, sa left side. Pagbaba ng mga bata, baka masagasaan.Last edited by turbo; January 27th, 2007 at 09:30 PM.
January 27th, 2007 09:48 PM #4
mali po kayo.. 3c-te po ang makina ng lucida/previa/emina.2.2L turbo na efi po yon. naka-tagilid makina nyan at nasa almost middle ng car...
about the door, its not a issue, reality, diba, park ka muna maayos bago baba, so paano ung risk na uyon kung nakapark ka ng maayos?
ang prob lang is mahirap ang stencil ng makina! and find ones w/ m/t, mas sulit sa power.
i recommend town/liteace-noah nalan, front mount engine, under the hood(not under the seat like sa nissan serena, mazda bongo/ford freeda), may nguso at parehong 3-cte din naman...
ang pang prob naman ng c series is ingatan mong wag maputulan ng timing belt, kasi hallow ang connecting rods kasi hydraulic valve lifters kasi..self adjusting po, kaya pag working temp. na, tahimik na makina.
another prob is ung oilseals, madaming oilseals ang c-series..kaya prone sa leaking
at pag efi may computerbox, so not all the time pag may warning, something big na..sensors lang po kalimitan ang source.
May 8th, 2008 01:39 PM #6
mga sir saan po kaya nakakabili ng surplus na assembly ng pang dual ac ng lucida? Mga magkano po kaya presyo nito?
May scanner na po na pwd mag reprogram ng new keys at delete the old keys. Kaya ata ni Jeep Doctor...
