I am driving a Revo SR 2001 2L Diesel and there are times that I encounter a weird problem.
Let us say I'm accelerating going from 60 - 80 kph and I'm in the 4th gear, pressing on the gas pedal, the engine working. Then suddenly, at around 70 kph, the engine stops working (but is still on), as if you released the gas pedal. No jerking like an engine brake, the engine just stopped roaring.
When my speed dropped to 60 kph, I re-pressed on the gas pedal again and it worked fine from that point on.
This problem occurs once in a while, and on different speeds/gears. What do you think is the problem? I passed by at Shell Tiendesitas and asked if the fuel filter should be replaced, and the mechanic told me that the fuel filter is fine.
There are several suspects:
1. fuel filter
2. fuel pump
3. air/water in the fuel line
I hope you can help me out! It is hard to prove/show during a test drive because the problem occurs in a random manner.
