Gud day guru's! Just wanna share and ask some questions regarding sa 2E cylinder Head. I just had a general overhaul of my engine.The plan was dapat Top Overhaul lang kaso, when the engine was dissasembled, ayun nakita ng mekaniko na may alog na mga piston.It was even oversized na raw to 0.75 maximum (which gives the reason malakas sya humatak pagdrive ko), so imbes na top overhaul lang, nauwi sa General Overhaul na.Changed piston rings etc.Sumasakit na din bulsa ko.My ride nga pala is a Corolla 91 XL.Which is understandable sakin dahil may edad na.Engine block is still in good condition.My question: Mga guru's will you have any idea magkano ngayon bentahan ng Cylinder head kahit surplus?Unfortunately, the prognosis on my old head is hindi na sya tatagal.Malaki na ang kinain sa pagkamachine raw, the reason kung bakit hindi ko na pina-machine din.I asked my mechanic kung pwede gawan ng paraan just to extend muna the life habang naghahanap at nagrerecharge ako ng bulsa hehehe.kinain na yun bakal ng tubig, pwede pa sya pero parang may anay na parang sa kahoy.Its also not the original.Any help will be appreciated po. I just need an idea kung magkano at saang mga lugar pwede makakuha ng abot-kaya.Salamat!![]()
Kung talagang wala k ng mahahanapan ng mura e try mo sa Cavite. Meron sa Imus along Aguinaldo Hway s tapat ng Meralco or sa Tanza going to Naic.
