Results 1 to 3 of 3
- Apr 2005
- 52
January 6th, 2016 02:26 PM #1Hi. I just bought a 2nd hand 2002 RAV 4 automatic, and it still runs very well, but it's such a gas guzzler! I'm getting less than 5 km/L!!! I'm actually not sure what's wrong yet with it, since it is running very well as I've said, but I think it's not supposed to be this gas-thirsty. I've been noticing that it always stays above 2200 RPM or so while cruising. Not sure if that's also a factor since it only goes to 4th gear. So I'm thinking if there's something wrong with the computer box, and if it can be tweaked. I also tried connecting a Bluetooth OBD-II adapter, but it doesn't get recognized, so I really don't have an idea what's wrong.
Anyway, does anyone here have an idea of what might be wrong, and if not, can someone recommend a reputable shop that can look into its electronics?
I live in Cainta, by the way, so it would be good if someone can recommend a shop in Rizal, Pasig, or Mandaluyong.
Thanks! Cheers!
- Jun 2011
- 134
January 8th, 2016 11:12 AM #2Sir,pag sa umaga ba during cold start up ano ang napapansin mo.kse normal is pag start 2k rpm then after 30 seconds dapat nasa 800 rpm nlng.pag above 1000rpm kahit mainit na makina,madumi ang throttle body mo.pag madumi TB, apektado elect throttle control.pag d lumalapat ng tama ang plato,magiging rich ang air fuel mixture mo.akala ng ECU nakatapak ka sa accelerator pedal kse nga d lumalapat ang plate, nakabukas sya ng konti.nagbibigay ng sobrang fuel injectors.7km/liter lang dapat ung consumo ng rav4 a/t na nka 1AZFE.Chka sir,ingatan mo wag mag overheat.PM mo ko sir.para makatulong.
- Apr 2005
- 52
January 12th, 2016 03:53 PM #3Hi. Sa umaga mejo mataas nga ang idling maybe because malamig pa sya pero pag umaandar na, parang mababa naman. Pero I think mejo mataas ng onti sa 800. Baka slightly above 1000 pag idle. Nag neu-neutral ako pag traffic tas mejo bumababa un idle nya. Yah I read nga na 7 km/l un consumption nya. Pero considering na 13 years old na un car, I'm sure me effect un. Pero I think mga 6 man lang, not 5 km/l. Buti mura gas ngayon, pero nakakaasar pa rin un bagsak ng fuel gauge everytime you move. Nde pa naman nagoover heat *knock on wood*.
Do you have a shop of your own somewhere near Cainta? Baka pwede ako dumaan minsan. By the way, un handbrake indicator is constantly lit sa instrument panel kahit nakababa naman un handbrake. Sabi nila sa computer box daw un? Not sure about it, and if it also affects consumption somewhat.
[QUOTE=ice15;3387274]medyo disappointing itong Sealion 5 No front sensor either Manual Seats...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
