Results 1 to 10 of 16
- Oct 2005
- 252
February 19th, 2008 05:24 PM #1hello guys... my corolla (lovelife) is in need of the following parts:
Front Shock Absorbers (Gas Type)
Rack End
Tie Rod End
Ball Joints
Front Wheel Bearing
Wheel Hub (optional daw)
Wheel Seal (optional daw)
medyo may tama na kasi kaya needs to be replaced... asap. i need 2 of each siguro... front lang kasi papalitan. i hope you can help me guys! baka you know shops (in banawe?) na padali puntahan where i can get a good deal sa aftermarket (brand new, reliable) brands na di gano masakit sa bulsa. sobrang mahal kasi ng original toyota parts... those parts would cost 35k++ daw OEM sa quotation ng toyota. hay...
thanks in advance guys!
February 19th, 2008 05:40 PM #2
if budget is an issue, just bring your car to zee or cruven.
but the 35k++ price that you've stated is a "casa" price. most probably, its a bit cheaper if you get OEM parts outside, and just let zee or cruven install them for you. that is if you want to use brand new OEM parts. zee or cruven would just only repair your damaged parts to make them on a "like new" condition. may warranty din sila so hindi ka lugi. pag kukuha ka kasi ng OEM parts outside, malamang walang warranty.
February 19th, 2008 05:52 PM #3
try mo part medics : 7880696
taurus di ko alam tel#, along arnaiz ave sila. kung galing SSHW, nasa left side sila. lampas lang konti ng evangelista.
February 19th, 2008 06:05 PM #4
nakalimutan ko pangalan nung shop sa taft ave., parang banawe sa parts at dun daw kumukuha ang mga toyota casa ng orig parts (tapos ibebenta ng 300-800%), specialty nila lalo na sa all models ng corolla, sobrang mura dun ako kumukuha madalas ng mahirap hanapin na parts, so most probably meron yung sayo na mas common..
di lang para sa toyota tabi tabi sila dun at depende sa store yung specialty, may pang mitsubishi, honda, nissan, etc..
- Oct 2005
- 252
February 20th, 2008 01:12 AM #61D4LV: sir can they repair those damaged parts provided i come to them early? just in case po, how can i contact them?
170kphlang and enzo18: yung shop po ba na sinasabi niyo as in original talaga na toyota parts? kasi po if that's the case i-contact ko na rin po. do you have that shop's contact numbers?
iba parin po kasi talaga pag oem... kasi yung corolla ko po was just handed down to me by my erpats... we bought it brand new, recently lang nagpahiwatig yung pang-ilalim na they need to be replaced na after more or less 7 years of use. pero ok din aftermarket parts just as long as may quality and di gano masakit sa bulsa...
thanks!
February 20th, 2008 11:56 AM #7
forbiddensmoke,
yup meron sila original, sorry wala ko tel# nila. bumili ako sa kanila ng replacement na bushing for power steering clamp, nasa P180 ung dalawa. ang original nasa P1700 ung dalawa.
February 20th, 2008 12:08 PM #8
For underchassis, get 555 japan parts. Subok na ito and it will cost you half of what toyota quoted you.
February 20th, 2008 12:26 PM #9
February 22nd, 2008 03:07 PM #10
8903101/8903657
Marco Auto Supply
Zapote near JP Rizal, Makati
Look for Dong.
Suki ko yan. Orig & replacement meron sila.
Xiaomi E-Car
