...differential allows the rotational speed of your ride’s inner and outer drive axles to differ as needed to go around corners. However, when it is subjected to hard acceleration, only one wheel starts to spin, and there will be no torque delivered to the non-spinning axle, hence the single tire mark you got on the road during your last burnout. Now if you want to maximize your power-to-pavement effectiveness, your diff will need a limited slip differential (LSD). Depending on the make, a limited slip differential can either be composed of small multi-plate clutches, planetary gears, or the viscous type that is made up of fluids, but is said to be less efficient than the former two. The LSD is able to transmit torque in a roughly 50-50 split between the two driving axles. So that when you execute your burnout this time, your car will now leave behind two trails of burnt rubber, and if your car has to go around a corner the clutch plates or the gears disengage for a while so that the axles can turn independently with one another.
LSD Lingo
1-way LSD – The LSD comes into use once the throttle is stepped on.
1.5- way LSD – The LSD comes into use once the throttle is stepped on and when the
car is braking there is a slight LSD effect.
2-way LSD – The LSD comes into use whether the car is accelerating or braking.
