Results 1 to 17 of 17
    Sirs,
    This week am buying my chosen AUV... and i am going for REVO.
    Ask ko lang po... Ang Diesel Engine ba ng Toyota Tamaraw FX are the same sa REVO?if not. kindly post naman po what makes them different.
    Thanks.;)
    Magkaiba po sila, the Tamaraw FX uses the 2C engine (2.0L) while the Revo is using the 2L engine (2.4L) which is also the same with Hilux pick-ups.
    Salamat Sir Ungas, thanks for the info. ito kasing tropa dito nabanggit na kalampagin daw mga Tamaraw FX na Diesel kaya heto muntik ng nabago yung decision ko.
    Kahit jurassic na ang design ng 2L proven naman ang durability and well suited pa sa Philippine environment.
    Would you believe that it has more HP than that of Crosswind? Hindi nga lang kasing efficient.
    Di naman sa kalampagin, but 2C engine are notorious for being a crap engine after few years of ownership. Baka po yung sinasabing kalampag galing sa disc spacers na kailangan palitan at pantayin. Original discs are 400/pair, while some owners do use the new 5 centavo coin as spacers, which will tend to produce more smoke if the original spces are not followed.
    ano kukunin mo? SR?
    whew, actually i just closed the deal this morning, i bought a REVO GLX Diesel. ang hirap mag-decide he~he~he~ it took me 2 months gathering info. about Adventure/Revo/Hilander, mas palagay ako sa REVO dahil na rin sa nakatulong mga input nyo.
    Thank you all....
    :D
    Congrats on your new ride! :D Binyagan na yan! Dalhin sa Tanay para mahasa sa offroad...
    Congrats po! hehehehe. Yung mga sinaunang 2C ay supplied galing Korea. Mas maganda na daw ang quality ng engines ngayon.
    ano ba ang features ng GLX as compared to isuzu XT?
    ilang HP 2L?
    hi lux 4x2?
    3L yung sa hi lux 4x4, 2.8L
    Yung mga naunang hilux pickup 2L engine nalimutan ko model LN105 yata yun (solid diffs front and rear). Yung bagong modelo IFS hilux models have 3L.
    I think 2L engines have 75 hp output, di ko na maalala yung engine specs.
    Eto po pala may nakita akong specs ng 2L engine:
    Fuel Type: Diesel
    Engine Model: 2L
    Engine Design: 4-cylinder In-line, 8-valve, OHC Belt Drive.
    Displacement (cc.): 2,446
    Bore and Stroke (mm.): 92.0 x 92.0
    Compression ratio: 22.2:1
    Fuel Supply System Distribution type: Fuel Injection
    Max. Output (PS/rpm.): 75 / 4,200
    (kW/rpm.): 54 / 4,200
    Max. Torque (Kg-m/rpm.): 15.4/2,400
    (Nm/rpm.): 151/2.400
    Once again Thank you all for the replies guys for answering all my queries in the past....
    Yeap Bibinyagan kaagad Test Drive puro akyatan >>> on Dec. 19th our route starts from Isabela enroute to Laoag via Aparri (8-9 hours drive) then on Dec. 21st from Laoag to Baguio taking Naguilian Road, then on Dec. 23rd from Baguio to Manaoag/Bonuan Blue Beach or San Fabian/Dagupan to meet Pangasinense Tsikoteer Chapters/ then on Dec. 26th from Pangasinan to Isabela taking Carmen >Nueva Ecija Route...
    For the following Pangasinense Tsikoteers Agagi(kapatid) kita-kits tayo Dude... CSI Mall pwede rin doon...
    1. Reuben a.k.a. Supierreman
    2. Rod Carolino from Dagupan
    3. Kinyo from San Carlos (turuan mo ko ng 5.1 Sound Set up mo)
    4. Aquirius
    5. Ronald a.k.a. Chieffy
    6. Rapeez
    7. Alsawagh
    Am hoping that somehow i could meet some Genuine Ilocano Tsikoteers Kabsat ken kabagis (kapatid)
    1. Jedi from Dingra Ilocos Norte
    2. Kennon Road from Laoag City Sulsona Ilocos Norte
    3. Cardo from Baguio
    4. 20vanda01 from Piddig Ilocos Norte
    5. Rsnald from Bacarra Ilocos Norte
    6. 48IDA from Baguio
    7. Sarangusong from Nueva Vizcaya
    8. ch0k0y from Naguilian La Union
    sana naman pm me your CP # contacts dadaanan ko lahat kayo on my one man trail... mini EB po tayo ...
    hmm, 1 day lang po me sa Manila, i might drop by to Chieffy and buy a Shirt txt na lang kita Sir Chieffy on Dec. 05th
    :hippie:
    Fuel Type: Diesel
    Engine Model: 2L
    Sir Ungas,
    Saan nyo nakuha ang specs na yan?
    Eto kasi ang nakuha ko sa toyota.com.ph:
    The 4x2 are no ponys either with a 2.5 liter diesel engine with more than enough power.
    Maximum Output: 83Hp/4,200rpm
    Maximum Torque: 162Nm/2,400rpm
    Sa Revo ay 86HP pa nga.
    Malaki ba ang difference ng PS sa HP?
    I just clipped it from a Toyota website. Can't remember where or what it was from. :D
    Here is the formula for HP, you can do the computations with the information gathered.
    HP = (TORQUE x RPM) / 5252
    English HP X 0.7457 = KW
    KW X 1.341 = English HP
    Metric HP (PS) X 0.7355 = KW
    KW X 1.3596 = Metric HP (PS)
    kg/m X 7.23 = ft/lb
    ft/lb X 0.13831 = kg/m
    kg/m X 9.807 = Nm
    Nm X 0.10196 = kg/m
    kg/hp X 474.28 = hp/ton
    KM/h X 0.62137 = MPH
    MPH X 1.6093 = KM/h
    kg/mm X 55 = pounds/inch
    pounds/in / 55 = kg/mm
    HTH
Different ba ang Diesel Engine ng FX sa REVO?
