Results 1 to 9 of 9
- Apr 2009
- 272
June 21st, 2016 08:13 PM #1Im having a hard time looking for a replacement of my corolla 1997 rear view mirror. Just want to ask if its ok to just use a vios rear mirror?
- Mar 2014
- 901
June 21st, 2016 08:20 PM #2I cant believe such a certain part has no available replacement, especially, a TOYOTA. Kung magkasukat ang mounting screw ng rear view mirror, pwede.
Starmobile Up+
June 21st, 2016 10:05 PM #3
Ano ba situation ng old rear view mirror mo?
Basag lang ba yung glass?
Kung basag lang you might want to consider using the wide angle mirrors na tinitinda sa Ace hardware or true value.
Less than 300 pesos mas malapad pa viewing angle mo na nakikita sa likod
Sent from my Asus ZenFone 2 using Tapatalk
- Apr 2009
- 272
- 54,286
June 22nd, 2016 01:14 AM #5i think some rear views are attached via special glue, to the glass windshield.
you should have little problem gluing one to your corolla, siguro..?
June 22nd, 2016 09:23 AM #6
Pwede but it may not be too nice if you don't get the proper adhesive. I'd stick with the original for the Corolla.
- Nov 2008
- 641
June 22nd, 2016 12:45 PM #7If you will opt to stick your mirror on your windshield, please do avoid using the local superglues such as Mighty Bond, etc. (no offense on these products). My friend had an experience with these and resulted in the breakage of his windshield. I guess the chemical properties of the superglue had a bad effect on the windshield.
June 22nd, 2016 06:16 PM #8
Have you tried the different surplus shops that sell parts? Parang malabo na mahirap hanapin. Try contacting Saulo or Tango since they have lots of surplus items
Sent from my Nexus 7 using Tapatalk
- Aug 2012
- 2,767
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
