Results 1 to 9 of 9
    Apr 2009
    Im having a hard time looking for a replacement of my corolla 1997 rear view mirror. Just want to ask if its ok to just use a vios rear mirror?
    I cant believe such a certain part has no available replacement, especially, a TOYOTA. Kung magkasukat ang mounting screw ng rear view mirror, pwede.
    Starmobile Up+
    Sep 2012
    Ano ba situation ng old rear view mirror mo?
    Basag lang ba yung glass?
    Kung basag lang you might want to consider using the wide angle mirrors na tinitinda sa Ace hardware or true value.
    Less than 300 pesos mas malapad pa viewing angle mo na nakikita sa likod
    Sent from my Asus ZenFone 2 using Tapatalk
    Apr 2009
    Loose ball joint na po. I think sa vios is nakadikit sa windshield?
    i think some rear views are attached via special glue, to the glass windshield.
    you should have little problem gluing one to your corolla, siguro..?
    Pwede but it may not be too nice if you don't get the proper adhesive. I'd stick with the original for the Corolla.
    If you will opt to stick your mirror on your windshield, please do avoid using the local superglues such as Mighty Bond, etc. (no offense on these products). My friend had an experience with these and resulted in the breakage of his windshield. I guess the chemical properties of the superglue had a bad effect on the windshield.
    Dec 2004
    Have you tried the different surplus shops that sell parts? Parang malabo na mahirap hanapin. Try contacting Saulo or Tango since they have lots of surplus items
    Sent from my Nexus 7 using Tapatalk
    Aug 2012
    Sent from my D5833 using Tapatalk
Is it possible to  install a vios rear view mirror on a corolla 97?
