Results 1 to 7 of 7
    Mga gurus, just want to know what to check or what had happened on AE92.
    Scenario:
    Last Monday walang redondo. (i checked the lights busina aircon okey naman)
    3months old palang ang battery.
    checked again on tuesday, dead pa din walang crank.
    but yesterday thursday, nagstart without any problems. do i need to bother checking something?
    Also pag morning hardstarting siya, need ko bombahin ang gaso, parang normal behavior niya. Any advise din on this.
    TIA
    Aug 2009
    Quote Originally Posted by vanityq View Post
    Scenario:
    TIA
    baka maluwag ang terminal mo sa batt. try to check. Pati na alternator mo check mo baka di na kumakarga.
    Quote Originally Posted by slalom View Post
    sir, already checked the terminal okey naamn po.
    Okey din yung alternator napacheck ko na.
    tinulak ko pala siya paatras kasi magsasampay sa garage, tapos nung ibabalik ko na wala pa din redondo, then tinulak ko paharap ulit. Any relation sa pagstart after a day.
    then after a day nagstart na siya ng normal.
    thanks sa replies.
    Have you checked the starter motor itself? The brushes might be worn out and need replacing.
    not yet sir, starter ang first suspect ko kaya lang biglagn nag start..
    thanks, will check it this weekend
    Even if the engine started, the starter is still suspect to have a problem.
    Given you have an old car, wear & tear issues should not be overlooked.
AE 92 no cranking
