Results 1 to 6 of 6
- Apr 2009
- 10
April 7th, 2011 11:58 AM #1toyota innova j rear wiper install help....
i there any body who have innova j variant installed a rear wiper?
sa mga nakapag pa install na po, pwede po ba malaman kung san pwede magpakabit nito? TIA
August 9th, 2011 02:59 PM #2
hopefully sana nga meron. anybody who can share any info it will be much appreciated. thanks.
- Apr 2009
- 10
June 21st, 2012 04:08 PM #3up for this thread, may nakita po kasi ako e, need ko po kasi wiper sa likod specially pag umuulan.
June 21st, 2012 04:55 PM #4
Jemson and the boys just did. Pero better if you buy your own motor and switch and sa kanila labor na lang.
Switch na pwede ay rear wipe switch ng older Toyotas like Lite Ace. Sa Hot Rod Banawe or Toyota dealer meron nun.
Wala nga lang intermittent mode unless you buy the intermittent relay box also.
Washer hindi ko natanong kung meron.
June 21st, 2012 06:02 PM #5
May Nakita na rin ako J na naka rear wiper..kaso wala washer mukang mas malaking trabaho ang washer system sa likod since iibahin ang water reservoir (2 motors ang may wiper sa likod) plus yung linya ng washer fluid. Butas nalang sa exterior ang kulang since may abang na na butas from body to tailgate (may rubber thing nrin- protection ng washer fluid hose)
June 22nd, 2012 08:39 AM #6
Importante may washer yung sa likod since most of the time, the dirt on the rear windshield is the road spray which is dirty.
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
