May recommended shop ba that sells Toyota electrical parts? I asked Toyorama puro mechanical lang daw sila. Our AE101 needs the ff:
- Denso headlight relay
- headlight switch assembly
- flasher relay
the relays are generic items that you can get from any well-stocked auto electrical parts store. the headlight switch assembly, being unique to toyotas, is probably easier sourced from parts stores handling toyotas. i suggest you bring the parts with you when you buy, so they can compare.. sometimes, manufacturers modify a part.. what about surplus? i do not recommend used electrical parts. too many questions on reliability..
