Results 1 to 16 of 16
    Hi.
    Any working ODB Scanner, diagnostic scan tool for Toyota Fortuner/Innova/Hilux/Hiace D4D model?
    I have Bluetooth ELM327 saka Autel Maxiscan, pero cannot work sa Fortuner/Hilux/Hiace. Hindi maread ECU.
    Pero both are working sa 2006 Toyota Vios and 2011 Mitsubishi Strada.
    Been searching sa forums pati sa ibang bansa, mukhang mahirap nga daw maghanap ng compatible sa mga auto na to.
    If may nakakaalam sa inyo or experience, please share! thanks!
    Jun 2011
    Try mo sir, pang asian market obd2 scan tool.Or check mo memoscan.cn.
    Nov 2014
    Sir mikevin.. san ka nakabili ng elm327 scanner na compatible sa 2006 vios? ang alak ko di pwede ang obd2 sa japanese made na toyota cars.. mobd ung gamit nila..
    Quote Originally Posted by bodeplot View Post
    Sir sa olx meron, mga ELM327 na color blue na bluetooth, ginamit ko sa 2006 vios to see mga KPH, sensors etc, readable naman, hindi ko pa natry sa check engine light, so tingin ko pwede, then ginamit ko din sa 2011 Strada, read and erase ng check engine light.
    Pero sa Toyota D4D(innova, hiace,fortuner) hindi ko mapagana, kahit read lang ng KPH sensors etc, no response.
    Jan 2009
    Some Toyota vehicles use Multiplex-OBD (M-OBD). The DLC may look identical to OBD-II DLCs but the pinouts and protocols used are very different.
    Simply put, you'll need an M-OBD capable scantool. Needless to say, they're quite rare and can be expensive.
    Yes sir, tama, naghahanap ako ng M-OBD scantool, too expensive and rare. Does not go below 10k range, so in case, worst is to worst, pa scan na lng sa toyota mismo for 1k++
    Jun 2009
    Quote Originally Posted by mikevin View Post
    Are you still using your ELM327? Matibay naman?
    Quote Originally Posted by anonemus View Post
    Bihira lang gamitin sir, ayos pa naman..
    Jun 2009
    Thanks. I bought one and it seems to be working fine. Not sure if it's durable though.
    Jul 2014
    Sa toyota maganda na scantool ay TOYOTA Intelegent or TECHSTREAM
    Quote Originally Posted by mrjeff View Post
    Thanks sir!
    May 2016
    Pwede ba sa 2005 toyota innova d4d yung techstream scanner?
    Jun 2006
    Iff i may ask, anong parameters ang na detect ng elm 237? Thru torque android app ba ang viewing? Any other program?
    Kahit sa vvti innova hindi kaya mabasa ang ecu?
    Tnx
    Oct 2013
    Hindi pwede elm327 sa d4d at vvti ng innova and fort
    Nov 2014
    Eto sir 100% working sa D4D using Techstream. Ordered thru eBay.
    Mar 2015
    I bought obdlink lx bluetooth scanner green color.ok sya kahit live date accurate and fast display sa sony xperia phone ko.connect it to my honda stream 2006.Pag uwi ko subukan ko sa montero kung pwede.
    Sent from my E6853 using Tsikot Forums mobile app
any working OBD diagnostic scan tool for Fortuner/Innova/Hilux/Hiace?
