Results 1 to 2 of 2
    Aug 2004
    Di ata lumitaw sa search ko :D
    May recommended shop ba that sells Toyota electrical parts? I asked Toyorama puro mechanical lang daw sila. Our AE101 needs the ff:
    - Denso headlight relay
    - headlight switch assembly
    - flasher relay
    Tnx!
    the relays are generic items that you can get from any well-stocked auto electrical parts store. the headlight switch assembly, being unique to toyotas, is probably easier sourced from parts stores handling toyotas. i suggest you bring the parts with you when you buy, so they can compare.. sometimes, manufacturers modify a part.. what about surplus? i do not recommend used electrical parts. too many questions on reliability..
Recommended shop for Toyota electrical parts
