Results 1 to 5 of 5
March 31st, 2012 09:09 AM #1
Check the owner's manual or shop manual for your car. It will tell you the minimum thickness of the rotors wherein it should be replaced. You can resurface your rotors as often as necessary, up until you reach minimum thickness.
March 31st, 2012 02:46 PM #2
Depends on the thickness of the rotors and whether it is warped or not.
I just buy a new set usually; replacements.Last edited by vinj; March 31st, 2012 at 02:50 PM.
- Sep 2008
- 54
That makes sense. Higher elevation has lower atmospheric pressure and even if the cooling system is...
