Guys, need your expertise here, ano kaya diperensya ng innova ko, may maingay na sound sa engine part. Parang huni ng ibon or may squeaky sound. Your thoughts will be highly appreciated. Thanks
Your concern is very subjective.
Here's a wild guess ......... fanbelt. To determine if it is, turn off the engine and dribble some water on the belt. Then start the engine, if the noise stops, either you have a loose belt (adjustment needed) or a worn out one (replacement necessary).
thanks to your quick response. usually pag nag start sa morning, naririnig ko sya then after a few secs nawawala na. but this time. all the way and napaka ingay na.
thanks retz, will consider your advise. chirping sound ang tunog nya.
if its howling sound, try search youtube if its similar to rav4 4d4 strange noise.
diesel bro. d pang karaniwan ang ingay and squeaking sound sya talaga. maski naka idle lang ang ang innova ko, maririnig mo sya. do you think fan belt sya?
