Results 1 to 11 of 11
    Jun 2009
    ayaw po maikambyo parang naka locked po pero pag pipindutin po ung kulay red o ung shift locked release dun sa tabi nia naikakambyo po, anu po kaya sira nia? salamat po
    Jun 2009
    up ko po
    automatic transmission po, salamat po
    Feb 2009
    Quote Originally Posted by alex412 View Post
    up ko po
    are you talking about the shift lock release? there is a manual release override. check your owner's manual
    Jun 2009
    hindi ko po kasi maikambyo kahit nakaapak ako sa preno parang naka lock po yong transmission pero po pag pipindutin ko po shift lock release naikakambyo ko po. dati ok naman po kahit hindi ko po press ung shift lock release.
    Feb 2009
    the system includes a brake switch, shift lock solenoid, the wiring,a fuse and the ignition lock cylinder. i would check the fuse first
    Feb 2005
    Baka mataas ang idle RPM ng makina. try mo muna paibaba.
    Jun 2009
    san po banda jan ung fuse nia sir?
    Quote Originally Posted by dest View Post
    try ko po mamaya sir, dati naman po na ganun ung idle RPM hindi naman namin ginagalaw sir
    Feb 2005
    Check mong apakan ang brake pedal mo kung umiilaw yong brake light. Yong Nakalagay na Stop. yon yong brake light fuse. Kasi bago mo ikambyo apak muna ang brake pedal.
    Jun 2009
    sir chek ko po wala ilaw yong stop light tas tinignan ko ung mga fuse ok naman po, anu po kaya sira nia?
    Feb 2005
    Check mo yong brake light switch sa brake pedal. May makikita ka dyan sa bandang ilalim. Check mo yong continuity kung may contact siya.
help po pls,  toyota prado model 90, ayaw maikambyo.
