Results 1 to 9 of 9
    Mar 2004
    totoo po ba na kinikikil yung suspension nang vios para ma ayos yung camber? bigla tuloy ako napa atras nung ganun ang sabi sa akin...
    sanay po kasi sa revo/innova na may eccentric bolt... yun vios po kasi sa sis-in-law ko... patingnan ko daw, wala kasi sya dito sa pinas.. salamat po
    sorry.wrong post..
    Aug 2004
    Quote Originally Posted by Zdre_Wulf View Post
    Try asking at speedlab: 02-376-4648 They got me an eccentric bolt for my Lynx. AFAIK, it should be universal for most Japanese compacts.
    Mar 2004
    thanks a lot po
    Mar 2004
    thanks a lot po
    Jan 2008
    ang alam ko pag Mc Pherson struts walang eccentric bolt to correct camber alignment, most vans like revo, innova, besta, l300 have eccentric bolts because they use wishbone type suspension where you can adjust camber via eccentric bolt on lower arm or removing spacers on upper arm..
    most of the time, Mc Pherson struts will not require camber correction unless your frame has been damaged or partially bent where the shock absorbers are placed, if you have camber problems, have your shock absorbers and shock mounting checked first
    Jan 2008
    Aug 2004
    There are no eccentric bolts as stock, but you can buy aftermarket eccentric bolts that will work with McPhersons. My Lynx has front McPherson struts.
    Mar 2004
    natanung ko na po speedlabs... kung meron sila nung bolt... nasa 3,200 daw.... pero mamya check ko po yung oto.... tangalin ko muna gulong hehehe thanks po sa replies
Vios Camber Adjustment
