Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    May 2008
    Mga sir patulong naman hindi ko kasi ma trace kung anu yung nag consume ng power ng battery ko even if hindi ginagamit at naka park lang always nalolowbat.
    na try ko naman measure yung battery reading after ko mag park ok naman 12VDC then after a few hours kapag measure ko ulit eh lowbatt na siya i think meron nag consume ng power kahit naka park lang. ang ginawaga mo muna ngaun is after ko magpag tinatanggal ko muna 1 terminal nung battery kaso hassle talaga mga bossing. baka na expirience nyo na to.
    My unit is altis 1.6G
    thanks in advance.
    May 2007
    If the battery is more than 4 years old replace it or maybe problem w/ the alternator.
    Jun 2006
    pa check mo sa electrical shop baka grounded
    ganito po nangyari sa trooper namin just a few weeks ago .. nag replace ako nang bagong battery pero kinabukasan drained out na naman ito .. turns out that may problem sa alternator .. pinacheck ko sa shop then turns out na madumi lang pala and may bearing na pinalitan then ok na ..
    the damage? only 930petot ..
    if the battery is 4 years old narin, baka kelangan na nito ng replacement .. but i recomend pa check mo muna alternator since expose na expose ito sa engine bay ..
    have you also tried battery reading while engine is running? you should be getting 13V or more. any mods you have done lately? sound system, amps?
    usually if ganyan... alternator na talaga yan. pacheck mo yung buong alternator, then also check for the grounds kung ok pa lahat.
    Something is draining your battery or your battery is old already (not consistent with the title though), such that it cannot retain the charge. Have your vehicle checked by a reputable electrical shop.
    6000:mobile:
    sounds like a ground or something doesn't switch off when the key is pulled out. Was there any work done to the car before the problem?
    May 2008
    Salamat mga bro, ang ginawa ko disable ko muna yung fuse sa me fuse box yung DOME magkakasama pala yung alarm at CD player, ngayon ok na 1 click nalang start ko kaso wala ako alarm,radio at keyless pansamantala.
    pansin ko din minsan kapag start ko mamamatay matay yung mga ilaw sa dashboard and blinking tapos kung saan saan pumapalo yung mga meter stick ng RPM, at ODmeter.
    tapos normal ba talaga na before start palang pag click palang is malakas na agad ilaw ng dashboard then kapag nag on ako ng headlyts humihina na ilaw ng dashboard
    May 2008
    Quote Originally Posted by v6dreamer View Post
    Sir mga 1 year palang yung battery ko, sa tingin ko ok naman alternator kasi nagchacharge naman cya yun nga lang madali ma lowbat
    May 2008
    Quote Originally Posted by s_quilicot View Post
    Sir ok lang ba pa check sa mga reputable electrical shop or sa CASA talaga, san ka nagpacheck?
    May 2008
    Quote Originally Posted by rion View Post
    Sir Already done battery reading while engine is running 12-14V DC, stocks lahat wala pako mods.
    May 2008
    6000:mobile:
    Sir got this altis sir last january lang 2nd hand nakuha ko siya na finance nung may ari sa toyota car financing, tawagan ko nalang siguro to get CASA records.
    thanks
    Quote Originally Posted by ervinnash View Post
    papatay-patay na ilaw sa dashboard ang kung san san pumapalo ang needle ng tachometer? well its the same thing na nangyare sakin .. lahat namamatay pati setero (all included) .. kala ko nga mamamatay yung engine ko eh .. sir baka po alternator talaga yan ..
    sa REYNOR alternator and starter shop po .. sa fairview area po ..
    baka po nagloloko lang alternator nyo .. just have it checked nalang sa mga reputable shops ..
    May 2008
    Sir yung nang yari sakin is before pa magstart yung engine patay patay na ilaw sir salamat sa mga inputs hanap nalang siguro ko reputable elec'l shop dito sa cavite pa check ko alternator ko.
    ok sir .. no prob ..
    if you are sure of good charging alternator. then it is grounded or your 1 year battery needs replacement na. kahit ok yung karga. basta faulty na yung battery. the charge will be lost after 24 hours.
    May 2007
    Are you using an amplifier in your car stereo?
    sir rion sabi nya kasi papatay patay yung gauge sa panel .. diba pag ganito it means drained out na battery and naglolokong alt? on off ang charging ..?
    patay yung gauge in sporadic, while engine is running kamo? mukhang tama po kayo s.q. nagloloko nga yung alternator. cases like this are classics.
Help new battery always lowbatt
