Results 1 to 11 of 11
    Dec 2008
    Good day sa lahat,
    I-konsulta ko lang itong problem ng rear windshield (w/s) wiper ng aming 2011 Avanza G.
    Walang tubig na lumabas pero yung actual wiper arm ay gumagana naman.
    Na-tsek ko na yung hoses na pinagkakabitan sa water reservoir.
    May 2 hoses na nakakabit, isa para sa front w/s at isa para sa rear w/s.
    Pag yung front wiper ang pinapagana, ramdam ko yung tubig na dumadaloy sa hose from the reservoir.
    Pag yung sa rear wiper ang pinagana, totally wala akong nararamdaman, hindi umaadar yung tubig.
    Aside sa clog hose, ano po kaya cause nito? Broken relay? Broken motor (kung meron man nito)?
    Baka may similar experience kayo you would like to share from any of your Toyota autos (Avanza, Fortuner, Innova etc) with rear w/s wiper, this is greatly appreciated.
    Salamat po sa mga magre-reply.
    Feb 2009
    Drive in reverse it might work[emoji1]
    Di ko gets.
    Oct 2014
    Di ko gets.
    The front will become your rear
    Oct 2014
    Quote Originally Posted by arvinmb1 View Post
    Good day sa lahat,
    Pag yung sa rear wiper ang pinagana, totally wala akong nararamdaman, hindi umaadar yung tubig..
    Di ko gets, what do you mean di mo nararamdaman ang tubig? at lalong di ko gets na di umaandar ang tubig??
    Oct 2014
    Do you mean to say wala kang makitang tubig (coming) from the wiper? Parang magulo pa din =(
    Feb 2009
    The back glass is REAR WINDOW, the front is the WINDSHIELD.
    Dec 2008
    My apology for any confussion I made. I was referring to the rear glass window when I initially said read windshield (thanks for the correction, jick.cejoco).
    * JJ All Day... bottomline walang lumalabas na tubig sa wiper para sa rear glass window, pero gumagana at umaandar naman ang wiper arm... Pag-iniikot yung knob(?) para sa rear wiper , wala akong nararamdamang flow ng tubig sa hose coming from the water reservoir.
    Broken relay? Broken fuse? Ano kaya cause?
    May 2007
    Good day sa lahat,
    try checking the rear wiper nozzle spray for possible clogging.
    Sep 2013
    Quote Originally Posted by airborn65 View Post
    TS, you might ask how to check for possible clogging by simply insert a needle into nozzle.
    Dec 2008
    Aside from hose clogging, any other possible causes?
No Water From Rear Windshield Wiper On Avanza
