Results 1 to 11 of 11
    Sep 2008
    Guys, sorry, i cant seem to find enough information about this
    I have an out of warranty 07 toyota fortuner gas that is due for the 40thousand km check
    do i get this service from the casa (14k daw )?
    or can you suggest other alternatives?
    thanks!
    Basta ako when the car is out of warranty automatic out of the CASA na ako... As to where? Sila na lang sumagot. Ako kasi dito lang sa Autocity (pag maraming gagawin like brake pads, spark plugs etc.) malapit lang samin pero kung change oil and change filter lang sa gas stations pwede na...
    out of warranty na pala...no need for casa na yan, mahal sa kanila tapos di pa makita kung ano ang ginagawa sa sasakyan mo.
    Jun 2007
    puwede rin naman ipa-check sa gas stations what part/s need/s to be replaced or repaired. then konting search ulit sa internet saan maganda magpa-repair for each part. kung ok lang din naman sa'yo, puwede na rin sa gas stations. stay away from CASA na.
    Aug 2005
    Quote Originally Posted by buchieboy View Post
    thanks!
    i agree na wag na lang sa casa dahil out of warranty na. saan ang location mo para mayroong makapag suggest na mga reputable shops.
    40,000 km pms. so ibig sabihin na papalitan lahat ng fluids tapos pa linis na rin ang aircon.
    Aug 2006
    40K Kms PMS, bili ka na lang ng Oil Filter (P425), Spark Plugs(P400) and Air filter(P1,062) sa casa, then have it service sa Caltex. Chevron chemicals/oils din naman ang gamit ng Toyota casa including the red coolant. Pili ka nalang ng matinong Caltex station with good Service Bay and mechanic.
    Sep 2008
    Quote Originally Posted by Mile2 View Post
    Guys, thanks sa mga replies usually magkano inaabot tuwing 40km check?
    Got a quote from speedyfix using fully synthetic oils, 14 k din inabot, ok ba dito?
    Apr 2009
    mahal pa rin. bili ka nang airfilter and fuel filter sa casa. (kasama na ito sa 40k checkup)
    tapos, punta ka nang gas station, doon ka na magpa-change oil, papalitan mo na rin fuel and air filter. palit spark plugs. flush radiator (doon na ang coolant sa gas station), change gear oil and differential (doon na rin ang gear oil bilhin). oops, A/T yata ang mga Fortuner na nauna, so tingin ko sa Casa ka na rin bumili nang ATF fluid.
    Pa-checkup mo na rin pang-ilalim. That's it.
    Aug 2006
    Around that price kung straight fully synthetic (engine, transmission, power steering, differential).
    Around 5K-6K (including OEM parts from casa) if you use straight mineral oils. Puede ka rin naman magpa-quote sa gas station para ma-compare mo, but then again get the oil filter, air filter and spark plugs sa casa.
    Fuel filter is to be replaced * every 80K Kms, medyo mahal ang fuel filter ng 2.0 or 2.7 VVTI nasa P3K++. Yung element niya ay kasama sa assembly/housing kaya mahal.
    Jun 2010
    It's really problem, thnx 4 help
40,000km maintenance check
