I am newbie here...kakbili ko lan ng 2nd hand car corolla 94 gli big body...though sa tingin ko okay naman makina medyo malakas pa humatak...here are my questions...
1. at first start walng ingay sa makina after I turn on the aircon...but after a while medyo parang may konting ingay na parang hirap ung makina...and parang mas malakas humatak ung makina pag naka off ung aircon...twice na kasi ako namatayn sa medyo inclined na road pag naka on ung aircon...is it norma? if not is there any way pa na ma fix ito?
matigas na magnetic clutch bearing and/or pulley ng compressor.
2. this may be a dumb queation pero is it normal na tlagang may usok na sa tambutso pag medyo nag revolution ako ng gas? I just noticed kasi na parang ung other cars ay wala nito.
anong kulay ang usok? pag puti, its coolant.... pag bluish, gray or black, its oil. you may need to have some oil seals replaced.
3. Sa aircon, pag mainit ung panahon parang blower lang ung lamig ng hangin pero pag gabi or umuulan sobrang lamig naman kahit nasa #1 lang ung lakas...do i need to replace something sa aircon? or I just need to put freon sa aircon?
check the freon level first. otherwise, it may be a defective condenser.
4. San ba maganda mag pa full check up ng car?
5. and san kaya pwede makabili ng cheap na bumper chin (rear and front) saka side skirt? plano ko kasi pormahan ung car...okay ba pormahan ung corolla?
6. Last po...anu ano po ang dapat ko i check for the maintenance ng kotse para maganda pa rin ang performance ng engine...thanks po...
regular oil change, throttle body cleaning, air filter change, fuel filter change, spark plug change. this is assuming walang tama yung makina.
Thanks bago lang kasi ako rito and I don't have much knowledge about cars...
