Results 1 to 19 of 19
    Sep 2009
    Our Vios 1.3E M/T has developed this issue, while in stopped traffic, the car in neutral with the aircon on the car's RPM would occasionally drop to 300-400 RPM almost stalling.....
    I don't know why this is happening.
    There are no check engine or other warning lights showing up.
    The car is only 21 mos. old, Casa-maintained (recent 25k checkup), not an ondoy victim
    I tried using V-power or Xtreme97 (at different gas stations) to lessen the rough idling but the issue still persists.
    Mar 2005
    Pa check nyo na yan sa Casa sir
    Aug 2004
    It's kind of early in the car's life for this... but check the idle air control valve and your vacuum lines. While the odometer readings are low, the rubber vacuum lines and IACV can be affected by heat in traffic.
    Quote Originally Posted by sm2by View Post
    using higher octane gasoline wont cure it. tama si sir jmpet626, have it check sa casa.
    wait. siguro kayo po ba na ginagawa talaga ng tama ang PMS ng auto niyo sa casa?
    be on doubt pa din.
    Sep 2009
    Thank you for your inputs guyz... I'll check with my CASA & SA about the issue.
    I will soon post a video, since I recently caught the problem on camera this morning at my office's parking garage...
    Sep 2009
    Video:
    [ame="http://www.youtube.com/watch?v=Zax0h0PilLo"]YouTube- 2008 Toyota Vios 1.3 E "Rough Idling"[/ame]
    ibalik mo sa casa.
    Jan 2003
    sana maliwanag yung sound para makilatis.
    it must've been a case of bad gasoline.
    Apr 2014
    Sir tanung ko lng po kung nasolve na po ung problem mo.at anu po ung ginawa. tnx. same din po tau ng problem
    2010vios 1.3e po ung akin.tnx
    linis throttle body and yung mga sensors for a start.
    Apr 2013
    try mo din sir pacheck battery. nagkaganyan auto ng tatay ko dati turned out palitin battery
    Posted via Tsikot Mobile App
    Apr 2014
    Quote Originally Posted by 1D4LV View Post
    Sir 1D4LV, naexperience na po ba kau ng ganito. nakakabahal kc ung ganung problem lalo na at andito ako sa manila panay ang traffic.cge sir try ko po ipalinis ung throttle body at mga sensor. tnx.
    Apr 2014
    sir same din po tau ng problem pa sabi naman kung nasolve na po problem nyu. tnx. 2nd gen vios po ung akin. tnx!
    Aug 2013
    Try cleaning your maf sensor and your tb then relearn your ecu.
    Ganyan din ang problema nung auto namin dati, sinabi sa akin na madumi lang daw yung servo nung Vios namin kaya low idling. So far after malinis yung servo, bumalik na sa normal idling at pati yung hatak nung engine umayos na din.
    Dec 2011
    Quote Originally Posted by GorgonioM View Post
    Same problem here. any recommended shop to do this job? Thanks
    Quote Originally Posted by carlrosario View Post
    yes, experienced it lots of times. make sure malinis mabuti ang lahat dun sa throttle body and sensors..
    i have an officemate na nagpalinis din ng TB, hindi nawala yung low and rough idling. sinabi ko magpalinis lang sa iba......
    nung nalinis, ok na sya.
    Sep 2013
    Quote Originally Posted by BoyAPV View Post
    guess wala kang suking shops/trusted mechanic. sa casa na lang para peace of mind ka. mayron silang gadget ( forgot the name) hooked up under the steering wheel para i-diagnose the cause.
    where are you located?
08 Vios 1.3E rough idling (300-400rpm)
