Results 1 to 9 of 9
    Mar 2013
    Good Day po sa inyo.
    Meron po akong Toyota Corolla Big Body po ako. May napansin po akong oil leak everytime nagpapark po ako sa bandang right po ilalim ng hood.
    Pahelp naman po sa mga tanong ko?
    1. Ano po kaya ito?
    2. May recommend ba kau na trusted shop na magaling magayos nito? Taga- QC po ako.
    Thank you for the time.
    May 2004
    pa lifter mo muna then tignan kung saan galing.. from there malalaman kung ano dapat palitan...
    Quote Originally Posted by IamLoveW View Post
    1. Ano po kaya ito?
    It really depends where the leaking is coming from. It could be a gasket or a bearing oil seal. Best way is to have the car lifted and have a peak under it too see exactly where it is coming from.
    Jul 2011
    Sir agapan mo yan, kasi langis yan mamya maging cause pa ng pagkasira ng engine mo yan, mas malaki ang gastos.
    Oct 2011
    hindi kaya ung sa aircon lang yan?
    Jul 2006
    Have your engine cleaned (washed) on top and below as well. When everything is nice and clean, you can now exactly pinpoint on where that oil leak comes from.
    "oil leaks" (especially with in-experienced car owners) can be from:
    1. the engine;
    2. the power steering;
    3. the radiator;
    4. the aircon condensate..
    5. the family dog!
    in my experience, searching for the source of the oil leak can be very frustrating.. even with a good engine wash.. good luck.
    Jun 2011
    1. Ano po kaya ito?
    your engine/transaxle orientation is east-west. meaning, the engine is at two o'clock and the transaxle is at ten o'clock in the car. if the oil leak is that of engine oil, the most common cause will be the front main oil seal, the camshaft seal or the oil pump seal
    Jun 2013
    1. Ano po kaya ito?
    Mas maganda, ipa engine wash mo muna at ipalinis mong maigi yung ilalim ng makina mo, then gamitin mo muna for a few days considering you always check your engine oil level. Then ipa lifter mo ulit at ipa sipat mo na sa mekaniko kung saan nanggagaling yung tagas. Madaming pwedeng pagmulan ng tagas at usually sa left side ng engine, kung saan nandun yung timing belt mo ( left side pag nakaharap ka sa makina mo) kasi nandun lahat ng oil seals at maganda pag pinabaklas mo, papalitan mo na lahat ng oil seals/o-rings, tsaka sa oil pump seal/gasket na common source din ng tagas. Pwede ring sa oil sump gasket lang or mismo sa drain plug. pwede rin sa valve cover gasket mo kasi pag malutong na, nalabas na rin ang langis lalo na pag barado rin PCV mo. Kung rear crank seal naman, medyo labor extensive kasi kailangan baklasin transmission mo pero sa transmission side naman ng engine mo dapat natagas. Unti unti mauubos din yan , hope this helps.
Oil Leak in my Car. Please help.
