Results 1 to 6 of 6
- Apr 2012
- 94
May 5th, 2013 12:12 PM #1on a cold start morning or hapon after galing office: bumababa ang menor ko kapag mag headlight/park light and kapag steady apak sa brake lalo na kung trapik..minsan namamatayan talaga.during cold start lng naman.pero kapag mainit na makina mga 1/4-half temp.ok naman..need your inputs mga master....
- Apr 2012
- 94
- Feb 2010
- 6
July 27th, 2013 12:13 AM #4Hi not really an expert but used to own a Lovelife Corolla, from my experience ganyan din. Every morning and after parking it for a whole day sa office especially when the headlights are on and braking for humps, definitely mamamatay and engine ko nun. I tried everything and nakita ko sa internet na baka IAC daw. Didn't help. Anyways, the culprit in my case was a torn rubber hose coming from the Air Intake metal thing sa liked hung cylinder head(?)(not sure what it's called sorry) going to the back of the engine. Try to ask a mechanic kung may mga tears or something. After this was replaced, my idle was back to normal and fuel consumption improved din. Hope this helps bro!
- Jul 2008
- 398
August 15th, 2013 06:14 AM #6based on actual experience.
diesel engine using caltex monograde sae40: lumpy low rpm at cold starts
changed to castrol gtx 20w50: significantly smoother and rpm increased at cold idle
conclusion: use lighter oil for better cold startups
Thread was made nung 2018 pa po sir.
