Results 1 to 3 of 3
    Dec 2010
    lumulubog brake pedal ko, then kapag nasa trAFIK, my rpm goes down. then i noticed na nagbabawas ako ng break fluid from high to low level sa reservoir in a weeks time. when you step on the brake pedal with the engine off, lumulubog yng pedal. ano kaya ang dapat ipaayos? Corolla xe big body ang car ko.
    Jun 2005
    check for leaks in your brake system, both vacuum and hydrolic
    Jan 2011
    mukhang yung break piston ang may problema kung wla sa master, check mo yung 2 break drums, makikita mo agad kung may leak basa siya ng fliud, palitin na yung mga rubber pa meron
Brake Fliud loss etc.
