Results 1 to 10 of 15
- Sep 2008
- 54
April 14th, 2010 10:07 AM #1hi mga autobots... hingi lang ako ng advise and opinions about my ae92, hindi ko kasi malaman ang problema ng auto ko kung sa carburador ba or aircon. kapag nag ON ako ng aircon nag aatoumatic sya at tumataas ang rpm which is tama, the problem is once I step on the gas hindi na bumabalik yun normal na rpm kundi nagwiwild pa ito at tumataas pa nga. Let say 900 ang rpm ko when a/c is ON, pag tumapak me sa gas at pinaabot ko sa 2000rpm hindi na bababa ito at stack up na dun. ano po kya prob ng autobot ko? your opinions will be deeply appreciate. thx
April 14th, 2010 04:09 PM #2
- Sep 2008
- 54
April 14th, 2010 10:51 PM #3sa tingin ko maayos nman yun cable.. kasi pag naka off na yun aircon ok naman un laro ng carb, pag ni rerev ko bumabalik nman. talgang hindi lang sya bumabalik pag naka on ang aircon.
April 17th, 2010 05:56 PM #4
parehas tayo ng problema sir, pero mas malala sakin kahit patay a/c nag-iistuck rpm nya above 1k! sabi ng mekaniko ko may problema na daw butterfly ng karburador ko, antay natin opinyon ng mga experts dito, sana may sumagot....
pero pag binomba mo gas pedal sabay biglang bitaw ng tapak bumabalik naman sa normal rpmLast edited by box_type; April 17th, 2010 at 05:58 PM. Reason: added more info
- Nov 2008
- 15
May 20th, 2010 03:33 AM #5same situation here sirs... i have a corolla xe97. when my ac is turned on, rpm idling is 1000 if neutral 1300-1400. before this happened, i had my carb cleaned at A&M kamuning. what should i do... i dont wanna go back to that shop again. they adjusted it for 3x and same thing happened. help please thanks.
- Apr 2010
- 9
May 23rd, 2010 06:01 AM #6Sana may mag post naman na expert sa thread na ito same din kasi ang problem ng kotse ko eh. GLI '97 stock lahat kapag naka idle 1.5k ang RPM pag naka AC 1k RPM pero kapag nag rev up maiistuck sya sa 2k RPM kapag pinatay ang AC babalik sa 1.5K RPM Haaay di ko alam kung ano ang sanhi nito.
- Nov 2009
- 456
May 23rd, 2010 11:42 AM #7
- Sep 2008
- 54
May 23rd, 2010 11:41 PM #9
i took my ae92 to kamuning and had it checked by Danny of D&M carb specialist (pasensya na kung mali yung pangalan ng shop di ko na matandaan) and mang Danny showed me what was the problem with my carb. Lumuwang na ung butas ng shaft ng butterfly kaya minsan tumataas rpm ko kasi daw may kawang na yung butas kung san lumalaro yung butterfly, ang tendency may hangin pa din pumapasok kaya mataas ang rpm pero pag binomba mo gas pedal natatsambahan na magsara fully yung butterfly. Wala da daw solusyon dun kung di palit carb na, kahit daw sa machine shop hindi narerepair yung part na yun, so wala ako nagawa kungdi bumili ng 2nd hand na carb (i bought it from someone who changed his engine), i hope tumagal pa yung nabili kong 2nd hand na carb, hth
- Sep 2008
- 54
May 30th, 2010 06:41 PM #10guys nalinis ko na yun iacv or un idle air vaccum.. pero ganun parin.. pag patay ang aircon ok na ok nman ang rpm nya, once binuksan ko na ang aircon at natapak na ako sa gas ayaw ng bumaba at nagwiwild sya umaabot ng 2000rpm. ano kaya problema nito?
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
