Results 1 to 2 of 2
    May 2010
    gud day po, need help from u guys regarding my toyota corona. Hard starting po ang problema. Already replaced battery and all sparkplugs. But still ayaw mag start. Nagka-crank naman ang starter pag iswitch-on. Ok naman ang mga fuse & relays..Ive checked the supply going to distributor kaya lang wala pong output supply papunta dun. Your suggestions and advice ay malaking tulong nyo po..thanks..
    Feb 2009
    Quote Originally Posted by reydaks View Post
    what you're saying is there is no power to T 15 (+ side) of the ignition coil. this circuit runs from the RUN terminal of the ignition switch to the positive side of the coil. there two paths to that terminal, the S (start) and the run. check the ignition switch first
hard starting corona 95
