Results 1 to 4 of 4
- Jan 2010
- 2
January 13th, 2010 12:37 AM #1gud pm... hi there... i have toyota corolla gli 95' (limited) i bought it 3yrs ago from a friend... ngyon naka set up cxa ng scub... dual scub...tas nkaheaders din na 4..2 daw... ask ko lang kung pwede ibalik ung stock muffler nya... kc maingay... n bawal na kc s subd maingay... ok lang ba nun?! ala bang mddamage sa engine?! tnx a lot..
January 13th, 2010 12:55 AM #2
You can have a muffler shop extend the existing cut pipe to the rear of the Corolla and install a standard muffler/silencer.
Pipe size would be 1.75 inch diameter for near stock specifications.
You might also want to install a big silencer (roughly the same size as the one for the rear) midway of the exhaust pipe under the middle of the car. This will help make the exhaust even quieter.Last edited by ghosthunter; January 13th, 2010 at 12:57 AM.
January 13th, 2010 02:26 AM #3
grabeng ingay siguro ng auto mo sir, naririnig mu pa ba ako sir? hehehe
anyways, ask ko lang kung nandiyan pa sayo yung stock slencer mu, if ever yun na lang ikabit mo, pero since 2nd hand yan gli mo, malamang wala sayo,
wala naman siguro magiging damage sa engine if "back to stock" ka, basta maayos ang pagkakagawa.
October 8th, 2010 02:25 PM #4
up ko lang sir... may silencer ba ang stock na muffler ng toyata corolla gli? gusto ko kasi marinig tunog nya.. paano kaya ito tanggalin?
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
