Results 1 to 5 of 5
    Sep 2008
    guys ilang beses nyo na pinarereface ang rotor disk nyo? anong basehan nyo na hindi na sya pwede? thanks
    kamii hindi na nag reresurface bili na lang kami surplus makapal pa 700pesos galing japan pa, dati nagtanong kung magkano pa resurface 400pesos daw edi bili na lang kami ng surplus makapal pa
    Jan 2009
    Check the owner's manual or shop manual for your car. It will tell you the minimum thickness of the rotors wherein it should be replaced. You can resurface your rotors as often as necessary, up until you reach minimum thickness.
    Depends on the thickness of the rotors and whether it is warped or not.
    I just buy a new set usually; replacements.
    Sep 2008
    pwede ba irefaced yun one side lang? or dapat laging sabay?
how many time pwede ireface ang rotor disk?
