Results 1 to 18 of 18
    Apr 2009
    Car is running smoothly at first but once it gets hot or if the car stays on the road for more than an hour ive notice rattling sound from the hood everytime i step on the gas pedal. Car although does not lose power but the sound is annoying. Theres no sound when the car is idle. Cant seem to find the cause of it. Im using corolla 1997 gli 1.6 with 110k mileage. Please help. Thanks
    Jan 2009
    I put my money on engine knock.
    If it is, there are a number of possible causes:
    1. Your fuel octane may be lower than what the engine needs
    2. Ignition timing too advanced
    3. Carbon buildup in the combustion chamber
    4. Wrong air-fuel mixture (ie. Too lean)
    5. Cooling system issue, causing hotspots in the cylinder (related to #3)
    Not sure if your vehicle already has an ECU. But if it did, it may also be a problem with the computer (though, unlikely) or the knock sensor (somewhat more likely).
    Mar 2005
    Gas up with higher octane mga 93 or 95 is better. Then report back. Mura na gas
    Agree that it may be detonation.
    1. When was the last time you tuned up your engine (change spark plugs and check timing)?
    2. What fuel do you use?
    Apr 2009
    Been using premium ever since. Nagpatune up na rin ako, ecu and change of spark plugs last november 2014. Masisira ba ang car if hindi to naayos?
    Quote Originally Posted by bail View Post
    if it is indeed engine knock, yes. masisira ang makina.
    errr... was it an intelligent tune-up, po? or was it done by the friendly by-the-ear neighborhood PUJ mechanic, who guessed more and measured less..?
    November 2014? How far has the car traveled since then? You should get a tune-up perhaps once a year if you don't rack up high mileages. Before, i'd check the timing and spark plugs (if using copper tipped) every 10,000kms.
    Have the MAF sensor cleaned also.
    Jun 2011
    Nka MAP(manifold absolute pressure)sensor po ang 4AFE,iba ang MAF(mass air flow)sensor.Tama ung mga advise na nauna.Fuel knock or tope yan.Pag mainit,umaakyat or sa traffic mo e2 maririnig.pacheck mo ung timing sa may timing light na nka diagnostic stage ang ecu.tapos 95+ octane rating.Try mo muna haluan ng octane booster gas mo.available sa ACE or sa mga suking auto supply.
    Apr 2009
    Around 9000kms already.
    Jun 2005
    How did they "tune up" the ECU? Afaik di pwede ito unless may programable ECU ka.
    Change gas ka lang. Okay na yan at palitan mo mekaniko mo kung nag "tune up" sya ng ECU mo
    Feb 2009
    The case of the bind leading another blind person. The Scientific Wild Ass Guess (swag)
    Apr 2009
    How much na ngayon magpa tune up ng ECU?any recommended place?
    Apr 2009
    Guys should i go for shell vracing nitro with 97 octane or the petron blaze 100?
    Apr 2009
    Anyone? Hope to receive replies soon
    Jul 2011
    having the same noise.
    changing to a higher octane gas did not improve. may tope parin.
    mine is avanza matic. already ask toyota yun culprit daw is pangit gas naten.
    ive notice pag malamig pa engine, wala naman tope pero pag matagal na sa road ayun na. irritating yun sound!
    any suggestion?
    Jul 2011
    sir bail manual or matic transmission ng kotse nyo?
    Feb 2009
    Check engine vacuum with a reliable vacuum gauge both with engine cold and at normal operating temperature at idle speed. You might have a VSV (vacuum switching valve ) induced intake manifold leak.
    Jan 2016
    it will be best to visit a trusted mechanic. You may just need a car tuneup or something else. If you don't have a trusted one yet, try to shop around.
Rattling sound during acceleration
