Results 1 to 10 of 10
    Oct 2013
    mga sir anu poh kaya solution sa power steering leak ng corolla XE ko ,,,n uubusan ako ng fliud at ang tagas dun sa my dalawang rubber sleeve sa left and right sa ilalim,, mga magkuno poh kaya magagastos ko at saan ipapagawa?
    Oct 2013
    Quote Originally Posted by aldrick View Post
    Ganyan din nangyari GLi ko, naubusan fluid, ang ingay manibela.
    Quote Originally Posted by JD_Reed View Post
    Check first if the leak is from the hoses, rack and pinion or from the pump. If you have the budget, pa-overhaul mo na lahat since moreor less, kabit-kabit yan.
    Jun 2011
    rack n pinion yan sir...
    mura lang yan... gastos ka mga 2.3k up to 2.8k...
    sa may banawe... malapit sa dating pcso... its not along banawe ha...
    meron area dyan sa banawe na malapit sa araneta ave... at e. rod... madaming gumagawa dun ng P.S.
    Sobrang mura naman 2.8k lang rack and pinion. Kung hindi papamachine shop yan, uulit lang tagas. And kailangan Orig yung repair kit.
    dami surplus nyan. at madami din repair kit. zafra motors mo na pagawa para sure ang alignment after.
    Jul 2017
    ganyan din un sa akin, leak rack and pinion, ang gnwa namin, pina hard chrome nmin un shafting, umabot 2k. tpos repair kit 2500. ngyn ok nmn. smooth na
    Jul 2017
    mga sir ask ko lang po, un axel s may transmission may leak, oil seal lng ba papalitan dun? and dna baba tranny? salamat po s reply.
    Quote Originally Posted by mlqz27 View Post
    maybe it's just the rubber boot (yung mukhang conical accordion). there's two of them on either side.
    but this is one part that might be cheaper than the labor involved to replace it.
    If dun sa axle sa may transmission galing ang leak, Oil seal lang dapat palitan. No need ibaba ang tranny, axle lang need bunutin para mapalitan yan. Usually magkaiba size ng left and right side oil seal. Hind dapat pinatatagal ito dahil transmission oil ang nababawas dyan.
power steering leak
