Results 1 to 5 of 5
    Aug 2007
    mga sir ilan po ba ang oil scapacity ng corolla xe bigbody last week kase nag pa change oil ako sa speedfix 3 liters nilagay nila after 3 days ko pa na check na kulang pala ng konti sa deep stick, Ok lng kaya na lagyan ko nalang ng oil additives para mag sakto ? any opinion ?
    Quote Originally Posted by noc_manila View Post
    mga sir ilan po ba ang oil capacity ng corolla xe bigbody last week kase nag pa change oil ako sa speedfix 3 liters nilagay nila after 3 days ko pa na check na kulang pala ng konti sa dipstick, Ok lng kaya na lagyan ko nalang ng oil additives para mag sakto ? any opinion ?
    di ko alam yung exact capacity, pero usually between 3-4 liters naman. kahit yung sa bigger brother nya na 1.6 4A-FE engine ay less than 4 din eh, nsa 3.4 li. yata.
    and before you think of putting any oil additives, mas ok imho na kung anong klaseng oil ang nilagay (pref. exact oil) during the oil change ang ipang-top off mo.
    sa speedyfix ka pla nagpagawa, sana inavail mo na yung RP promo nila.
    3.25 to 3.5 liters bro.
    Mar 2003
    2E oil capacity
    Dry fill = 3.4 liters
    Drain and refill:
    with filter = 2.7 liters
    without filter = 2.5 liters
    3L should just be fine. Even the Nissan 1.6L engines only need roughly 3L... AFAIK, the reading on the dip stick represents roughly the last liter (more or less) on your engine so you give it a little slack (better that its a bit short from F then being over F)
toyota corolla big body oil capacity
