Results 1 to 7 of 7
    Oct 2011
    Hi Guys,
    I'm new here, ask po lang kung anong mga reason bakit parang maalog ung nabili naming revo, pag sa highway sobra para akong nasa papag. Second hand na Toyota Revo GLX 2002. Pwede po bang sa shocks to?
    Thanks in advance.
    Feb 2009
    Quote Originally Posted by kronossaturn View Post
    Hi Guys,
    Thanks in advance.
    have your tires and wheels balanced, checked for tires age and condition, tires for out or roundness, checked for wheel runout, checked for wheel bearing roughness and adjustment. it is already showing you some problem symptoms, it is your and your passengers' lives risk. have a thorough assessment of the suspension and steering
    Oct 2011
    Hi jick.cejoco,
    Thanks for your quick reply. Serious problem na pala sya kala ko naman sadyang ganun lang. thanks a lot.
    Hi Guys,
    Thanks in advance.
    dagdag ko:
    check your shock absorbers. that's why they are called that.
    also, if you're coming from a sedan, then any AUV will be more matagtag..
    lastly, baka naman matagtag talaga ang road surface!
    good luck.
    Aug 2010
    maalog..hmmm,.... can you show a picture of your Revo GLX, hindi kaya kung bakit maalog e, inadjust ng previous owner yung torsion beam (yun know trying, to drop it low/make it lowered effect) kaya nagiging maalog, kasi ang underchassis ng revo ay napakatibay at hindi basta-basta nagkakasira yan, yes maalog yan kung idadaan mo sa roughroads and potholes pero kung nasa hi-way nagiging pino naman ang laro ng suspension ng revo, di naman basta basta maglalaro ang shocks niyan kung rektahan ang takbo at walang mga lubak, the only weakpoint of revo is transmission.
    Jan 2011
    San ba maalog, harap or likod? hindi ba siya nilowered ng dating owner? yes check mo din yung shock absorber baka may leak na, means sira na din kaya matagtag, kung sa likod naman medyo matagtag nga kse dahil sa leaf spring, pero pwede din mawala yung tagtag niyan, nag additional ako leaf spring sa likod, bilhin mo yung pangatlo na muwelye, medyo mag lift ng konte pero ngaun hindi na matagtag
    Nov 2011
    dagdag ko:
    good luck.
    Hello Revo owners! Bago din lang ako dito, I just bought a second hand Revo SRJ with a 2.0 engine last June, giving up my corolla car for this. Ang mapapansin mo not only to an AUV but also sa mga vans (I used to commute TTh riding in vans, dala ko revo MWF) ay talagang matagtag especially sa uneven roads pag konti ang laman. Napapansin ko eto pag konti pa lang pasahero ng van, pero nawawala malakas na tagtag pagka puno na ung van. I notice din eto sa revo ko although di naman cya gaano maalog sa highway, usually tatlo lang kaming sakay neto. Also check mo na rin pangilalim like shocks, leaf spring, etc.
    Ang problema ko naman ay with regard to steering. Medyo malambot yung aking steering, medyo hindi sya responsive gaano or sloppy. Nagpalit na akop ng tie rods and rack end at bearing. Nabawasan ung pagiging sloppy nya pero di pa rin gaano natatangal, especially pag irregular yung rod surface parang pumapaling ng konti, so I need to exert a little effort para lang magremain cya onstraight line path. Para sa mga nakaexperience na ng ganito, kindly help me with this.
Maalog na Toyota Revo GLX 2002
