Results 1 to 6 of 6
    May 2009
    Mga bro yung toyota gli 94 ko, umaabot ng 1800rmp idle nya, pero kung naka a/c drop sya ng 800-1000rpm nakasagad na yung idle adjustment nya pero ganun p rin, need your help. thanks and God bless us all.
    Feb 2009
    Quote Originally Posted by Elliot View Post
    check for vacuum leak and check the coolant temperature sensor
    Aug 2009
    *jick.cejoco sir ano nangyayari pag sira yung coolant sensor? yun din ba yung tinatawag na thermo switch? sira kasi sakin eh minsan mababa menor nanginginig pero hindi naman erratic.
    *elliot ganyan sakin sir dati yun pala may singaw sa valve yung may hose sa itaas ng block head. san pala yung idle adjustment niya?
    May 2010
    Check aircon IDLE UP. Palitan mo kung kelangan. May pinipihit dun to adjust the idle.
    Apr 2008
    Sir, ganyan din yung sakin before. What I did was to have the throttle body assembly cleaned and nawala bigla. Start with the cleaning lalo na pag di mo pa pinalinisan. Maraming thread dito regarding erratic idling for you to check, search mo lang.
    Mar 2011
    bro, try mo re start computer box by disconnecting battery terminal for 30 seconds then ibalik mo ulit..
Toyota GLi 94 idle too high! (1800rpm) please help.
